Solution for surrounds too close and centre below image - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By Ratman
  • 2 Post By Alan P
post #1 of 19 Old 02-12-2020, 05:41 PM - Thread Starter
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 380 Post(s)
Liked: 163
I was mucking around in my theatre and came across an idea to solve the problem of side surrounds being too close to the side of the couch and the centre speaker being too low below the TV.
I put my side surrounds (sealed enclosure) behind the couch at ear height but pointing directly away from the couch and towards the wall (turned 180deg from their usual position in other words). The sound is then reflected back to the listeners but is now coming from twice the distance and due to the increasing cone of sound is less direct and virtually reduced the hotspotting to zero.
Then I thought it may work for the centre speaker too, so I pulled it out, turned it round 180deg and angled it up to point just below the centre of my screen and it actually worked
So this could be a solution for narrow rooms (where there is a solid wall to each side of the seating) and for people who can't do an AT screen but still want the sound to come out of the screen/TV and not from below.
niterida is online now
post #2 of 19 Old 02-14-2020, 10:02 AM - Thread Starter
Quoted: 380 Post(s)
Liked: 163
No-one has any thoughts or comments ?
post #3 of 19 Old 02-14-2020, 10:10 AM
Ratman's Avatar
Quoted: 2589 Post(s)
Liked: 2417
If it works for you... that's great. Enjoy.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #4 of 19 Old 02-14-2020, 10:14 AM
Alan P's Avatar
Quoted: 6975 Post(s)
Liked: 6810
"Bouncing" the surrounds to create a more diffuse soundfield had been around for decades and I have used that trick myself in the past with great results!
However, reflections for the center channel are always discouraged and usually end up "smearing" the dialogue...but like Ratman says; whatever works for you!
Alan P is offline
post #5 of 19 Old 02-15-2020, 06:35 AM
Bigus's Avatar
Quoted: 713 Post(s)
Liked: 625
Don't place a center below a screen. That's my suggestion.
Bigus is offline
post #6 of 19 Old 02-15-2020, 07:58 PM - Thread Starter
Quoted: 380 Post(s)
Liked: 163
I don't - I have an AT screen
I just thought people might like to pursue the bounce option when they are limited for placement and more for the less dedicated viewing/listening environmet.
I have never seen this method mentioned here before during many threads on speaker placement so I just threw it out there.
I am very happy with my bouncing side surrounds after living with them for a few days. In my room it is better than having them either directly to the sides at approx 3' away and better than at 80deg (slightly in front).
post #7 of 19 Old 02-16-2020, 09:56 AM
Supa Mint's Avatar
Quoted: 14 Post(s)
Liked: 8
I'm a newbie, so I don't have any 'original' ideas or beliefs, so please take my comments with a grain of salt. But what about utilizing acoustical treatments on the walls, to minimize the reflections that are causing you to need a compromised workaround?
Supa Mint is offline
post #8 of 19 Old 02-18-2020, 09:19 AM
Quoted: 400 Post(s)
Liked: 110
How about bouncing the surrounds at a 45 degree angle and pointing up to the ceiling and back wall? Would that work?
Scottt1174 is offline
post #9 of 19 Old 02-18-2020, 09:29 AM
pappaduke's Avatar
Quoted: 487 Post(s)
Liked: 484
How about angling the center up towards ear level?
Man cave-Marantz 8012, Oppo 203, 4K ATV, FireCube 2, Sony XBR-75X940E, Bluesound Vault 2, Harmony One, 2 Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's,
4 SVS Prime elevations. B&W P5. Living room- Yamaha 2010, Bluesound Node 2, Paradigm SE-1's, Zone 2-Paradigm-Stylus 370-SM. B&W PX for travel
Bedroom- Samsung UN60ES7100F, Oppo 103D, Pulse Mini, JBL Bar Studio, ATV3 and Harmony 650
pappaduke is offline
post #10 of 19 Old 02-18-2020, 10:02 AM - Thread Starter
Quoted: 380 Post(s)
Liked: 163
This solution is for side surrounds that are too close to your ears - nothing to do with reflections causing issues and it is not what I would call a compromised workaround. I have been listening to the reflecting side surrounds for a while now and IMO they actually sound way better than speakers firing directly at me form 3' away.
What the ??
But the sound is still coming from below the screen. If you turn the speaker around 180deg and point it up slightly at the centre of the screen then the reflected sound you hear appears to come from the middle of the screen and not from below it.
post #11 of 19 Old 02-18-2020, 11:35 AM
Ratman's Avatar
Liked: 2417
And write "Bose" on the back of the speaker.
sivadselim and Mashie Saldana like this.
Ratman is offline
post #12 of 19 Old 02-18-2020, 07:52 PM - Thread Starter
Quoted: 380 Post(s)
Liked: 163
Que ??
post #13 of 19 Old 02-19-2020, 04:30 AM
Ratman's Avatar
Liked: 2417
Esta aqui:
301® Direct/Reflecting® speaker system
https://www.google.com/search?client...4dUDCAo&uact=5
Ratman is offline
post #14 of 19 Old 02-19-2020, 04:54 AM - Thread Starter
Quoted: 380 Post(s)
Liked: 163
Esta aqui:
Now I hear ya
Not quite what I am describing though.
If I get enough motivation I will post up some pics or drawings of what I mean for those that I have not explained myself properly to
post #15 of 19 Old 02-19-2020, 07:49 AM
Alan P's Avatar
Liked: 6810
Oh, we get it. You turned your CC around, angled it up and bounced it off the rear wall behind your AT screen...doesn't take a rocket scientists to visualize it.
We are just saying that theoretically it should not work very well...but if it works for you, enjoy!
Ratman and sivadselim like this.
Alan P is offline
post #16 of 19 Old 02-19-2020, 10:48 AM - Thread Starter
Quoted: 380 Post(s)
Liked: 163
Yes and No
Yes - I turned the speaker around and bounced it off the front of the AT screen (which has a non-AT material behind it except where the centre speaker is of course).
No - it does not work for me as I do not run this - it was just a 2-second experiment to see if it worked. I am sticking with my centre behind my AT.
My side surrounds however are working very well bouncing off my side walls
post #17 of 19 Old 02-19-2020, 11:59 AM
Ratman's Avatar
Liked: 2417
Just curious...
What is the make/model/size of the AT screen that you purchased?
Ratman is offline
post #18 of 19 Old 02-19-2020, 04:53 PM - Thread Starter
Quoted: 380 Post(s)
Liked: 163
Just curious...
Its a DIY spandex.
post #19 of 19 Old 02-20-2020, 04:25 AM
Ratman's Avatar
Liked: 2417
Ah... I was wondering who "manufactured" a screen with a cutout in the middle for a CC speaker.
Ratman is offline
