System Synergy, Fact or Fiction - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 90Likes
post #391 of 469 Old 03-10-2020, 02:37 PM
Scotth3886's Avatar
Quoted: 4414 Post(s)
Liked: 2764
Originally Posted by m. zillch View Post
What's also weird is your 12 second into Murmur peak isn't even all that large. There are many other areas that look way more (potentially) problematic. I don't get it. [And it sounds fine on all my DACs but I don't have your speakers.]
Well, piano is very very difficult to get 'right', and that's the worst IIRC, but not the only piece that had the issue. I think there was an Einauldi piece that also did it. I looked and couldn't find the others. I also tried Murmur with the Maggies in this system and it wasn't noticeable much at all if any.
It's similar to when I really went arse deep into the high-end in the 90s, in that if I wanted to compare, it was the ML Statements v the Soundlab A1s, but most everything sounded the same with the Maggie MGIIIa. Now, by that time, I'd sold the Tympani IVa s to get the Statements to have the room and the money. Maybe with the much bigger IVa I would have heard some difference? With the Soundlabs and the Statements, there was more difference between the VTL300s and the Classic 150s than there was between the two pairs of ESLs, but with the Maggies, it pretty much sounded the same. And its not just panel size that led to the issues as the CLSs were pretty brutal too with something they didn't like.
Name:	CLS in RPV.jpg
Scotth3886 is offline
post #392 of 469 Old 03-10-2020, 02:41 PM
Scotth3886's Avatar
Liked: 2764
What's also weird is your 12 second into Murmur peak you've gripped about before isn't even all that large. There are many other areas that look way more (potentially) problematic [see the clipping indication graph under the main one]. I don't get it. [And it sounds fine on all my DACs, but I don't have your speakers.]
Btw, it was all through that piece, but the first one at about 12 sec in was a shocker and after that I was hiding under a pillow. But yes, you're correct, that entire piece was a mess.
post #393 of 469 Old 03-10-2020, 08:48 PM
Scotth3886's Avatar
Liked: 2764
Originally Posted by Scotth3886 View Post
What else would you do with a 1/4 million bucks that weighs 500 pounds ea.
https://youtu.be/jyrjhv1pjac
What a cute piece of kit. Even double power down to 2 ohms for 6,000w
"With its 5.5-kilowatt power supply feeding roughly 100 output devices, the Relentless Monoblock easily delivers 1,500 watts into 8 ohms—and when connected to a 220-volt outlet, it doubles its output to 3,000 watts into 4 ohms and 6,000 watts into 2 ohms, all while maintaining the same musical composure it offers at a mere 1 watt."
https://www.dandagostino.com/product...-monoblock.php
post #394 of 469 Old 03-10-2020, 08:56 PM
m. zillch's Avatar
Quoted: 6766 Post(s)
Liked: 4980
^ Does the Jules Verne, green submarine light in the front make the sound more better and stuff?
Out-Of-Phase likes this.
m. zillch is offline
post #395 of 469 Old 03-10-2020, 09:00 PM
Scotth3886's Avatar
Liked: 2764
Although if I were to go that kind of money, I'd probably still go VAC
post #396 of 469 Old 03-10-2020, 09:03 PM
m. zillch's Avatar
Liked: 4980
I bet that amp's top plate costs more than all my stereo system components I've ever owned, combined.
post #397 of 469 Old 03-10-2020, 09:06 PM
Scotth3886's Avatar
Liked: 2764
Although, frankly, I'd probably stop short the VAC's $80,000 phonostage
post #398 of 469 Old 03-10-2020, 09:08 PM
Scotth3886's Avatar
Liked: 2764
And I thought my ARC Classic 150s were such hot chit in the mid 90s. My VTL 300s were pretty ugly or utilitarian as some might say.
post #399 of 469 Old 03-10-2020, 09:09 PM
Scotth3886's Avatar
Liked: 2764
Yes, moar gooder !!!
post #400 of 469 Old 03-10-2020, 09:20 PM
m. zillch's Avatar
Liked: 4980
This technology is so old they didn't even have color.
post #401 of 469 Old 03-10-2020, 09:26 PM
Scotth3886's Avatar
Liked: 2764
https://www.youtube.com/watch?v=nA_tgIygvNo
Ain't it wonderful?
post #402 of 469 Old 03-10-2020, 09:28 PM
m. zillch's Avatar
Liked: 4980
They knew about the future though, including talking motion pictures, radar, television, and this little wonder:
post #403 of 469 Old 03-11-2020, 07:31 AM
ClawAndTalon's Avatar
Quoted: 655 Post(s)
Liked: 494
https://www.youtube.com/watch?v=V9xUQWo4vN0
It’s quite amazing how so many demand that audio reproduction be more expensive and difficult than need be, while confirming their exercise with the absurd and unfounded.
"Most theories on audio and audio reproduction will be proven wrong only when the laws of physics change."
ClawAndTalon is offline
post #404 of 469 Old 03-11-2020, 08:22 AM
Ratman's Avatar
Quoted: 2926 Post(s)
Liked: 2995
That's synergy for ya!
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #405 of 469 Old 03-11-2020, 08:30 AM
Scotth3886's Avatar
Liked: 2764
I'm all for looking for synergy between components, but I'm just not willing to pay all that much for it anymore.
post #406 of 469 Old 03-11-2020, 11:24 AM - Thread Starter
DreamWarrior's Avatar
Quoted: 1452 Post(s)
Liked: 965
Good thing it's pretty much unnecessary!
Here's a few interesting points:
Driver distortion increases as excursion increases -- less movement = "cleaner".
To increase driver excursion, one must increase power.
To decrease driver excursion one must: make the driver larger, use "physical" amplification (horns / waveguides), add more drivers.
Then you have the "first watt" folks with speakers so insensitive and so hard to drive that the "first watt" is "useless" claiming how much it matters that the "first watt" be the "best watt".
It's so ridiculous!
IMO, the best sound comes from well engineered systems and rooms. If one gets there without "engineering" the system then either they got lucky or the school of hard knocks eventually pounded something useful into their thick skull (that could've been learned more quickly through learning the actual underlying science). If I'm being honest, in my case, it's a bit of both (and I'm still assuming my system sounds any good to anyone but me, lol).
CharlesJ likes this.
DreamWarrior is offline
post #407 of 469 Old 03-11-2020, 11:29 AM
Ratman's Avatar
Liked: 2995
Things you read and learn here are ...breathtaking.
post #408 of 469 Old 03-11-2020, 11:33 AM
CharlesJ's Avatar
Quoted: 927 Post(s)
Liked: 715
At least if not much more better.
CharlesJ is offline
post #409 of 469 Old 03-11-2020, 11:39 AM
CharlesJ's Avatar
Quoted: 927 Post(s)
Liked: 715
Ok. now you can resume breathing.
CharlesJ is offline
post #410 of 469 Old 03-11-2020, 11:39 AM
Scotth3886's Avatar
Liked: 2764
No question, moar gooder.
post #411 of 469 Old 03-11-2020, 11:42 AM
Scotth3886's Avatar
Liked: 2764
It's so ridiculous!
No thanks. I'll pass.
post #412 of 469 Old 03-11-2020, 11:42 AM
Ratman's Avatar
Liked: 2995
post #413 of 469 Old 03-11-2020, 11:47 AM - Thread Starter
Liked: 965
That's fine, you can reject controlled and repeatable for "tinkering randomly" -- I'll pass on random tinkering, though. I'd much prefer a methodological means to achieving a result...you know, so I can repeat the result again and again without suffering through more "random tinkering". My hobby is listening to the music, not f'ing around indefinitely until it sounds right to me.
CruelInventions likes this.
post #414 of 469 Old 03-11-2020, 12:04 PM
Scotth3886's Avatar
Liked: 2764
Thank you. I appreciate that.
Once the 'science' evolves to the point it can give me some answers/guidance regarding my listening priorities, I might change my ways. Until then, random tinkering is the way.
Sorta like Gerry Lemay @ HAA Min 44:00 and on.
For specifics: min 49:45, 50:25, 51:00
post #415 of 469 Old 03-11-2020, 12:23 PM - Thread Starter
Liked: 965
https://youtu.be/4G03l1eyU4s?t=2599
Honestly, I hope it does "evolve", but I think it has and continues to. There are so many room sims and speaker sims and...I mean, what they can do to design venues in software is insane. But, that's not my day-job (I'd code one in a heart-beat, though, if someone wanted to pair-up). Thus, you'd have to talk to a Keith Yates-esque person to get the lowdown on existing tools that can help in this domain and if the SOA tools can account for "dimensional perception" (whatever that'd mean).
Unfortunately, most people are focused in the wrong areas to see any evolution. Like, for example, thinking amplifiers have a huge difference when modern ones do not and (even if you must believe they do, they absolutely should not). Unless, of course, it is by design, and then I'd call the amplifier an "artistic amplification tool" -- certainly not a hi-fi amplifier; this may be fine for the content creators but it is not fine, IMO, for hi-fi playback.
Regardless, "random tinkering" is most definitely not the way science works; no "random tinkerer" will ever produce a valid scientific study without removing every last bit of "randomness" from it -- that's not how science works.
For the pedantic, lol, please keep in mind the use of the word "random" here is best read as "uncontrolled".
P.S., I want to clarify that "fine for the content creators" doesn't mean I think they should use "artistic amps" to playback music in the studio. I mean if they want to include them in the recording process (e.g., hook up their guitar to something that distorts in a pleasant way) then fine! DO NOT USE IT TO LISTEN TO RECORDED MUSIC! It's not the job of an amplifier to add anything but gain to a signal. If it does anything else you're either using it wrong (e.g., overdriving it) or it belongs outside the playback chain! Moreover, if those "other things" the amp does are useful in any way then there exists a stand-alone device to do it! Fortunately, that device can at least be removed from your signal chain when you don't want it there!
post #416 of 469 Old 03-11-2020, 12:27 PM
Out-Of-Phase's Avatar
Quoted: 399 Post(s)
Liked: 374
At the end of the day, it never did anything good for you anyway. Better sound? Meh.
Save your money.
Out-Of-Phase is offline
post #417 of 469 Old 03-11-2020, 12:27 PM
Quoted: 399 Post(s)
Liked: 374
Ain't it wonderful?
https://youtu.be/C3_-2fUm6y0
No.
Save your money.
post #418 of 469 Old 03-11-2020, 12:28 PM
Quoted: 399 Post(s)
Liked: 374
Ridiculous.
Save your money.
post #419 of 469 Old 03-11-2020, 12:30 PM
Quoted: 399 Post(s)
Liked: 374
Why? Are you going to weld in your living room?
Save your money.
post #420 of 469 Old 03-11-2020, 12:34 PM - Thread Starter
Liked: 965
LOL! No, we're going to hook up a six-pack of MBL 101Es in parallel so they are near impossible to drive with anything else...in a cold room so it doubles as a space-heater (don't want to waste all that inefficiency).
edit: but, seriously, I "get it"...it's like building a 1000HP car, right? I mean, no one "needs" it. The difference, however, is that I can go drive a 1000HP car to its limits either illegally on the street or legally at the right track. If there exists a speaker that requires that much power to operate properly and I owned it then I'd reevaluate my choice of speaker!
