Do I need a external amp? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By m. zillch
  • 1 Post By niterida
post #1 of 4 Old 04-09-2020, 09:33 PM - Thread Starter
SyNTaX's Avatar
Quoted: 20 Post(s)
I currently have 2 pairs of elac B6s, Elac C5 and a pair of A4s hooked up to Yamaha aventage 1070. I plan on upgrading to svs towers, center, elevation, and surround. Emotiva has the basx 5175 on closeout and I was gonna pick it up to future proof. Our current movie listening volume goes up to around -15 at the most
SyNTaX is offline
post #2 of 4 Old 04-10-2020, 12:02 AM
m. zillch's Avatar
Quoted: 6438 Post(s)
Liked: 4639
No, not likely.
If you played content closer to full "0 dB" and heard distortion on loud parts, moved to a much larger room and increased your seated distance, or if you switched to markedly less efficient speakers you might need more power. . . and in that case the Emotiva you mentioned probably wouldn't cut it because it is only a little more than what you currently own.
SyNTaX likes this.
m. zillch is offline
post #3 of 4 Old 04-10-2020, 05:33 AM
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 452 Post(s)
Liked: 216
Originally Posted by m. zillch View Post
No, not likely.
I agree with that. I would hear distortion running my RX-A3040 above -10 so I upgraded to an external amp and upgraded my speakers - now it is crystal clear at 0MV.
But it is virtually identical to before at anything below -10.
SyNTaX likes this.
niterida is offline
post #4 of 4 Old 04-10-2020, 06:54 AM - Thread Starter
SyNTaX's Avatar
Quoted: 20 Post(s)
Thanks for the input guys
SyNTaX is offline
