Best method for playing music from external HDD? - AVS Forum | Home Theater Discussions And Reviews
 10Likes
  • 1 Post By Roseval
  • 1 Post By philpoe
  • 1 Post By philpoe
  • 2 Post By polkandwhat
  • 1 Post By JimMeader
  • 2 Post By Worf
  • 1 Post By mickinct
  • 1 Post By philpoe
post #1 of 23 Old 05-09-2020, 12:44 AM - Thread Starter
Ryan Statz's Avatar
Quoted: 1218 Post(s)
Liked: 902
Does it require a network player or is there a simpler, less expensive solution? My music setup is outlined in my signature.
Home Theatre: Marantz SR6014 | KEF Q750 Front L/R | KEF Q650c Centre | KEF Q150 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is offline
post #2 of 23 Old 05-09-2020, 01:34 AM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
What music file format? It may be able to be played from the USB port.
http://manuals.marantz.com/SR6014/EU...Ykxqlluoz.php#
For servers, I'm not too familiar with it, but there's probably several NAS options or maybe even one of the game consoles has an app that can do it.
Worst case, there's probably a Raspberry Pi option out there.
http://manuals.marantz.com/SR6014/EU...SYelkngxze.php
philpoe is offline
post #3 of 23 Old 05-09-2020, 01:42 AM - Thread Starter
Ryan Statz's Avatar
Liked: 902
My music setup uses a Cambridge Audio AXR100. The Marantz is for my HT.
post #4 of 23 Old 05-09-2020, 08:57 AM
usc1995's Avatar
Quoted: 486 Post(s)
Liked: 348
A network music player is the best way to play them and you may already own a suitable device. If you have a game console or streaming box that can run apps like Plex you can setup a server on your network pointed at your music and have the files playing rather quickly. Some Bluray players also can act as UPNP or DLNA endpoints and act as players too. If you don’t have a suitable device then a Raspberry Pi is a very cheap device that is simple to set up for this purpose. You can use your choice of quality USB DACS and a Raspberry Pi 3 with this image and be up and running in twenty minutes or less https://www.picoreplayer.org
You can easily control playback via a smartphone app and setup access to online services like Spotify, Tidal, Pandora and Tunein internet radio.
usc1995 is online now
post #5 of 23 Old 05-09-2020, 08:58 AM
Roseval's Avatar
Quoted: 88 Post(s)
Liked: 54
A simple solution is a laptop.
As the Cambridge has SPDIF input only, use a USB to SPDIF converter to connect the two.
Ryan Statz likes this.
Roseval is offline
post #6 of 23 Old 05-09-2020, 09:41 AM - Thread Starter
Ryan Statz's Avatar
Liked: 902
Thanks, I'll look into getting a converter. I can use bluetooth from my computer, but it doesn't work the best!
post #7 of 23 Old 05-09-2020, 10:06 AM
sam_canavo's Avatar
Quoted: 157 Post(s)
Liked: 41
Ryan, I am using one of these from my htpc, way better then the onboard soundcard.
https://us.creative.com/p/sound-blas...rround-5-1-pro
I see they have a new one
https://us.creative.com/p/sound-blas...aster-x3#specs
Maybe more then you need though.
Got those 750 setup yet
Denon 3400h, Kef LS50s, Kef Q250c, PSB Sub Series 125 and Paradigm adp-190s, Atrium4 Front Heights
55 Q80r, Optoma HD 2200, ps3 and HTPC- Living Rm
Yamaha YAS108, 55 lg lk520-Bed Rm
sam_canavo is offline
post #8 of 23 Old 05-09-2020, 11:41 AM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
*v8foreheadsmack* I read that umpteen times and still focused on the Marantz.
For the AXR100, an option may be an app-controlled device that can play from USB and output over optical.
The Sony SMP-N100 fits that description, and also has a remote (in case you have a learning one), and can stream from a DNLA server if you ever go that route.
philpoe is offline
post #9 of 23 Old 05-09-2020, 12:07 PM - Thread Starter
Ryan Statz's Avatar
Liked: 902
I have a MacBook Pro laptop, so I can't exchange any internal components, and I am not in the market to build a HTPC I think I'll look into the USB to SDIF/RCA adapter, and go that route in the meantime. A cleaner option, which I'd prefer, would be to just have an external plugged in, but I think it would require an extra component with some kind of display to navigate the files (cambridge audio's CXN, for example). If the adapter works, then I'll have no problem doing that instead, though!
Have not gotten the Q750s yet - still waiting on the retailer to ship (it's been 5 business days with no progress on that yet). I get the Q650c on Wednesday, though.
post #10 of 23 Old 05-09-2020, 12:30 PM - Thread Starter
Ryan Statz's Avatar
Liked: 902
If it's not too expensive I can also look into that option, too - thanks! I've done an initial search, but it comes up as discontinued, but I can look into other similar items/perhaps a newer model.
post #11 of 23 Old 05-09-2020, 12:42 PM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
They may be hard to find new, but I see a number of them used on ebay/the net for cheap via google shopping
The newer SMP-N200 seems to have dropped the USB port. I stopped searching via Sony models after that.
There are probably other models/brands, but that one popped up first.
philpoe is offline
post #12 of 23 Old 05-09-2020, 12:56 PM
Liked: 5
a suggestion, might not work for you if your HT & music setup are in different areas of your home.
if your SR6014 is connected to modem/router, then you can connect the FAT32 HDD to the USB port of the modem/router, enable DLNA in the modem/router and use the excellent DAC in AVR to decode music in almost any format. use direct/ pure direct mode in AVR and connect either L/R or Zone 2 pre-outs to the Cambridge using a good quality 18AWG RCA (if the distance is more or else 22AWG ) cable and you are all set. i know its not ideal, but doesn't involve any new expenses, except for RCA cable. and with HEOS, you can control this from your mobile phone.
Ryan Statz and philpoe like this.
polkandwhat is offline
post #13 of 23 Old 05-09-2020, 03:59 PM
Quoted: 44 Post(s)
Liked: 29
something like an Nvidia Shield would work, all music formats are recognized as well a 4k video
https://www.nvidia.com/en-us/shield/shield-tv/
it has a HDMI out that would plug into your Marantz.
The Shield can be a Plex host which will find your music either plugged into Sheild or on a NAS drive
interface shows up on your TV
Jim Meader
Audirvana on Win 10 PC, USB out to SMSL SU8 DAC, XLR out to Crown XLI 1500 amp, full range signal sent via RCA to 12 inch Klipsch sub, Audirvana accesses FLAC Music files on USB Drive
JimMeader is offline
post #14 of 23 Old 05-09-2020, 07:35 PM - Thread Starter
Ryan Statz's Avatar
Liked: 902
They're both within the vicinity of each other, but I am purposefully keeping them separate, so whatever can easily connect to my AXR100 is what I'd be after. There are a few promising options mentioned so far.
post #15 of 23 Old 05-09-2020, 11:34 PM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
If the router and/or a game console gets you a DLNA server and you don't want to connect the HT system, besides the Sony model mentioned before, there are a 2 inexpensive (<$50) DNLA-capable streamers I've been looking at that weren't mentioned because they don't play from USB storage.
Dayton Audio WBA31 has optical and analog out (and can actually play from SD card if you copy some files over). It uses a proprietary app based on a lesser know ecosystem, but is AirPlay compatible.
https://www.parts-express.com/dayton...emote--300-597
Phorus PR5 has analog out, no optical, but claims to have some great DAC. It's Play-Fi and AirPlay compatible. It's WiFi only, no ethernet. It has a USB port, but from what I can tell, it can't play media from it. It can take a USB-based ethernet port if you don't want to rely on a wireless connection.
http://phorus.com/pr5-receiver
philpoe is offline
post #16 of 23 Old 05-10-2020, 12:13 AM - Thread Starter
Ryan Statz's Avatar
Liked: 902
Would a Schiit Modi 3 do the trick?
post #17 of 23 Old 05-10-2020, 04:15 AM
Worf's Avatar
Quoted: 935 Post(s)
Liked: 667
MacBook Pro should have optical out built in, you just need a 3.5mm optical adapter. Audio output jack is a combined analog and digital output.
Worf is offline
post #18 of 23 Old 05-10-2020, 12:55 PM - Thread Starter
Ryan Statz's Avatar
Liked: 902
Has that always been the case? Mine is a mid-2012 before they made things less consumer-friendly, and those awful glossy screens.
If that's the case, a $3 cable should do the trick!
post #19 of 23 Old 05-10-2020, 01:00 PM
mickinct's Avatar
Quoted: 272 Post(s)
Liked: 949
THis what i use love it 2tb of space. https://www.thebrennan.com/itemlist.php/clasrefr/units
MickinCT
mickinct is offline
post #20 of 23 Old 05-10-2020, 03:38 PM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
Apparently it came out in 2005, but was later removed (2016?).
https://www.reddit.com/r/apple/comme...ical_line_out/
https://appleinsider.com/articles/16...headphone-jack
https://support.apple.com/guide/mac-...s-cpmh0052/mac
philpoe is offline
post #21 of 23 Old 05-10-2020, 03:43 PM - Thread Starter
Ryan Statz's Avatar
Liked: 902
I'll give it a shot - I actually have an audio to RCA cable I can try.
post #22 of 23 Old 05-10-2020, 03:53 PM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
According to the apple support link you need a toslink miniplug adapter to make the jack able to take a cable, or an optical cable with a 3.5mm plug adapter
Amazon has a couple of things
http://www.amazon.com/outstanding-Di...dp/B07SL5DM5X/
http://www.amazon.com/FosPower-Tosli...dp/B00T8HWUVS/
philpoe is offline
post #23 of 23 Old 05-17-2020, 05:37 PM - Thread Starter
Ryan Statz's Avatar
Liked: 902
Update: got a 3.5mm to Toslink cable, works perfectly. I can now pay music from my computer. At least I can until it dies. Another alternative, I think is I can transfer a whole bunch of music to my iPad, and connect the RCA to 3.5mm cable I have if I want to be able to use my computer at the same time as listening to music.
