Rear speaker mounting with drop ceiling? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-16-2020, 06:19 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 3
99% sure I will be going to a 7.4.4 system. Haven't cut any holes for speakers yet but really struggling with the placement of the rear speakers. The rear of the theater is open so the rear wall is not an options as its really in another living space of the basement. I have room for the 4 atmos speakers in the ceiling but really am not sure how to mount the rear speakers. They will have to be on the ceiling. Any suggestions for mounting rear speakers with with a drop ceiling? Sides have room in the wall but the rears are an issue at this point. At least in my mind. I can have them placed below the celling, as terrible as that will look it might be my only option.
For the record, same with the PJ and the Atmos speakers because the area has a drop ceiling and the initial quote for a drywall ceiling is north of 20k. So thats not happening...Never dealt with a drop ceiling before so any advice for speakers and PJ mounting is welcomed.
DietCokeFan is offline
post #2 of 4 Old 05-16-2020, 08:50 PM
RayGuy's Avatar
Quoted: 3485 Post(s)
Liked: 3295
5.x.4 and be happy.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #3 of 4 Old 05-17-2020, 05:29 AM
Dawn Gordon's Avatar
Quoted: 526 Post(s)
Liked: 377
What is your Atmos budget? Triad has special mounts for many of their ceiling speakers that are designed for drop ceilings.
________________________________________
[email protected]
Dawn Gordon is offline
post #4 of 4 Old 05-20-2020, 06:10 PM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
Why not use the side walls again for the rear surrounds? As long as they're in or close to the arcs defined by dolby, the AVRs room correction should adjust for timing and volume based on distance. Of course they'll have to be angled properly.
If you don't want on-wall, there are angled in-wall speakers if you want that.
Does the dropped ceiling have light fixtures? The Atmos speakers should be a similar installation. For the projector, install a pole in the joists above above and cut a hole to get below the panels leave enough room for the cables.
If for some reason weight is a concern, put a structural "beam" in the joists to support the weight of whatever hangs flush with the dropped ceiling.
philpoe is offline
