Where to place surround speakers (5.1) - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Jonas2
  • 1 Post By RayGuy
post #1 of 9 Old 05-17-2020, 11:22 AM - Thread Starter
Liked: 0
Hi All, I have 2 options to mount my surround speakers (5.1 setup). One is a the back wall, and another left and right of the coach (pretty much in the middle of the room).
Which option is better? (see attached images)
ID:	2728034   Click image for larger version
RedDasher is offline
post #2 of 9 Old 05-17-2020, 11:24 AM
Quoted: 237 Post(s)
Liked: 262
A.
Polyrythm1k is online now
post #3 of 9 Old 05-17-2020, 11:28 AM - Thread Starter
Liked: 0
Originally Posted by Polyrythm1k View Post
A.
Do you mean left/right of coach?
post #4 of 9 Old 05-17-2020, 11:28 AM
tre74's Avatar
Quoted: 59 Post(s)
Liked: 86
A for 5.1, A + B when you go 7.1
tre74 is offline
post #5 of 9 Old 05-17-2020, 06:09 PM
Quoted: 237 Post(s)
Liked: 262
Yep. And then as mentioned, A+B when you go 7.1.
post #6 of 9 Old 05-18-2020, 08:39 AM
Jonas2's Avatar
Quoted: 3224 Post(s)
Liked: 2155
A. And don't be afraid to experiment with moving them slightly forward of the couch too, unless you simply can't do do. I've got mine at around 80 degrees, with either side aimed just forward of the opposite most listener. With monopoles, this delivers the overall best experience for the 3 positions on my couch.
RayGuy likes this.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #7 of 9 Old 05-20-2020, 02:40 PM
RayGuy's Avatar
Quoted: 3461 Post(s)
Liked: 3268
Whatever position you end up with, be sure the speakers have line-of-sight to each seated head. For instance, putting the speaker at ear height at exactly 90 degrees would be problematic, as the head of one listener would block the speaker from the other listener on the couch. Position forward, backward, or use additional height to resolve this issue and go with whatever option sounds best.
Jonas2 likes this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #8 of 9 Old 05-21-2020, 03:18 PM
philpoe's Avatar
Quoted: 156 Post(s)
Liked: 55
As has already been mentioned, l/r speakers are better for 5.1, and the rear wall is better suited for the rear surround channels if you can angle them in a bit.
If it helps, here are the Dolby setup guides
https://www.dolby.com/us/en/speaker-...des/index.html
philpoe is online now
post #9 of 9 Old 05-23-2020, 08:50 AM
teetertotter's Avatar
Quoted: 31 Post(s)
Liked: 29
I am for R/L of couch for the surrounds. Then experiment with height and maybe a little bit behind the head for starters. Are the fronts angled in to the central listening position and like? Good luck!
TV: TCL 55" 4K UHD HDR - Vizio 50" HD - Vizio 40" HD [All w ROKU]
DENON AVR-S910W, 7.2, 4K UHD HDR, 4K Upscale SD/HD, Atmos, WI-FI
KLIPSCH: L/R: R-15M - Ctr: R-25C - Sub: R-100SW - POLK S-10 Surr
SPKR Wire:Windy City Wire USA - 16AWG, 2 Cond, Stranded, Oxy Free Copper, Shld, Jacket
HDMI: VANCO Premium ---[AT&T Directv, AT&T DSL 100Mbps]
teetertotter is offline
