Bipole speakers for my space - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-17-2020, 11:06 PM - Thread Starter
SyNTaX's Avatar
Quoted: 20 Post(s)
There is a door to the right side of the left rear speaker that leads to the bathroom. And to the right side of the right rear speaker there is a opening thats roughly 25 feet or so high and a landing and stairs that go up to second story. If I was to put bipoles, would the speaker on the right side of bipole on the rear right reflect sound and echo sound up the stairs making it sound horrible in the room? And is the left speaker too far away from left wall for bipole ?
Or should I mount bookshelf's (currently have svs prime satellites mounted in the rear). Horrible sketch attached
SyNTaX is offline
post #2 of 6 Old 05-18-2020, 01:12 AM
sivadselim's Avatar
Quoted: 572 Post(s)
Liked: 516
Do you mean dipoles, maybe?
Either way, though, why do you want to use bipoles/dipoles? Do you already have them or something?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #3 of 6 Old 05-18-2020, 06:56 AM - Thread Starter
SyNTaX's Avatar
Quoted: 20 Post(s)
bipoles, Klipsch rp-502s. I'm currently using svs prime satellites
SyNTaX is offline
post #4 of 6 Old 05-18-2020, 06:58 AM - Thread Starter
SyNTaX's Avatar
Quoted: 20 Post(s)
SyNTaX is offline
post #5 of 6 Old 05-18-2020, 01:32 PM
sivadselim's Avatar
Quoted: 572 Post(s)
Liked: 516
Do you not like the SVS Primes for surround duty?
post #6 of 6 Old 05-18-2020, 01:43 PM - Thread Starter
SyNTaX's Avatar
Quoted: 20 Post(s)
I don’t like the difference in sound from the from and back. I have klipsch reference premiere in the front. If the bipoles won’t work in the space, I’ll probably get rp-400m
SyNTaX is offline
