Dolby PLIIZ without side speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-18-2020, 10:58 AM - Thread Starter
LittleLarry's Avatar
I have an older Denon receiver that only has PLIIz (no Dolby Atmos options).
Due to room constraints, I can only have Main R and L, Center, Sub, and Height R and L, no side or rear speakers.
Has anyone else attempted this?
Does it sound ok or is it not even possible to set up in a Denon AVR? (Planning on testing this weekend if it is even possible). It would hopefully create a larger front sound stage by sacrificing the right and left side / back speakers....I hope.
Denon AVR-2313CI
Klipsch RW-12D on Gramma
JBL Northridge Series N24|| x 6
JBL Northridge Series N-CENTER||
LittleLarry is offline
post #2 of 3 Old 05-21-2020, 04:31 PM
Espo77's Avatar
Quoted: 518 Post(s)
Liked: 227
Listening in straight mode is one option...two channels and sub.
Any two channel programming can be “expanded/processed” to PLIIZ and out of the additional spkrs.
With most regular TV watching...almost everything, and music from Spotify I’ll be using DSP. Try it.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #3 of 3 Old 05-21-2020, 11:30 PM
m. zillch's Avatar
Quoted: 6482 Post(s)
Liked: 4676
Although you can have side/rear surround speakers yet no front height/wides, I don't think the opposite is true. The side/rear surround speakers are considered key before you can expand to yet other effect speakers.
You could trick your AVR, ignore any auto calibration routine and force it to think you have 7 speakers hooked up, yet the surround side/rear are actually missing, but this is not sanctioned and you will fundamentally be missing material it sends off to the missing speakers.
m. zillch is offline
