Setting up 4K TV with AVR (not 4k supporting) - 5.1 Sound required - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-19-2020, 12:54 AM - Thread Starter
soodgautam's Avatar
Liked: 0
Question Setting up 4K TV with AVR (not 4k supporting) - 5.1 Sound required
Dear All,
I need some help in setting up my Home Theater + PC + Smart TV
Below are the details of the devices
AVR - Denon AVR 1912 (8 years old and does not support 4K)
TV - 75 Inch Samsung Smart TV (Supports 4k)
PC - Have a GeForce card which has 2 HDMI out and both support 4K
Now the issue is that as my AVR does not support 4k - So I have to connect HDMI from PC to TV directly.
For Audio I have 3 options
Option 1 - Optical (SPDIF) from TV to AVR:
Issue is that I am not able get 5.1 output from TV to AVR
Option 2 - HDMI ARC from TV to AVR:
Option 3 - Second HDMI from PC to AVR to just transfer audio:
Issue is that in this case my graphic card starts treating AVR like a second/extended display creating issues
Is there any other way to solve this issue?
Thanks in advance for the help.
soodgautam is offline
post #2 of 2 Old 05-19-2020, 02:12 AM
Ryan Statz's Avatar
Quoted: 1197 Post(s)
Liked: 881
You need to plug any of your devices directly into the TV's HDMI inputs - note that not all of the TV's inputs will support 4K HDR.
Then you run the optical from the TV's Optical output to your AVR's Optical input.
I would check the selected sound modes in the AVR to make you you have the correct one selected. And make sure that the AVR knows to receive the TV's audio signal to the AVR's Optical input. And I would also check your TV's settings to make sure it knows to allow the AVR to control the audio output.
I had to figure this out for my in-laws who had just gotten a 4K TV, but had an AVR that wasn't up to date (I even think it was the same model).
Home Theatre: Marantz SR6014 | Polk Audio RTi A3 Front L/R | KEF Q650c Centre | KEF Q150 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch | TBA: KEF Q750 Front L/R
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is offline
