Combining Gauge Wire Runs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-19-2020, 09:25 PM - Thread Starter
Quoted: 88 Post(s)
I have run wire that cannot be moved or replaced for my 4 in ceiling speakers. Wire is 14 gauge in-wall rated wire. I will be connecting these to a wall plate for hooking up banana plugs outside the wall to the AVR. I would prefer to use 12 gauge wire to connect to the AVR for multiple reasons, but I want to know will this cause any issues whatsoever? It’s not a long enough run where to gauge wire should effect it at all, just wasn’t sure if this will cause an issue to my equipment or speakers going AVR -> banana plug -> 12 gauge wire -> banana plug -> wall plate -> 14 gauge wire -> speaker.
5.1 Setup || Marantz SR-7012 & MM-7025 | Paradigm Prestige Series - 95Fs, 55C, 15Bs | SVS PB16-Ultra | Sony XBR-65A9G | Panasonic UB-9000
Apple TV 4K | Amazon Fire TV | Furman Elite 15-PFi | Logitech Harmony Elite | Samsung Smart Things Hub | Amazon Alexa Integration
JayNTee is offline
post #2 of 3 Old 05-20-2020, 03:19 AM
Wayne A. Pflughaupt's Avatar
Quoted: 522 Post(s)
Liked: 436
It's not a problem.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #3 of 3 Old 05-20-2020, 01:18 PM
gbynum's Avatar
Quoted: 110 Post(s)
Liked: 42
As Wayne said it is not a problem. It's very common to do the opposite in power wiring, run long distances in a larger conductor and use "tails" of something you can easily handle. Think of your house wiring as an example, almost certainly #14 or #12 from the electrical panel to the receptacle, then #16 or #18 from the receptacle to your device's power supply.
gbynum is offline
