Measurement Mic stands - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By CalJake
post #1 of 7 Old 05-20-2020, 11:23 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 26
Hi I plan on getting a mic stand.
What do I ask for, is this correct.
Mic stand with extendable boom.
Thanks in advance
Philips752 is online now
post #2 of 7 Old 05-21-2020, 12:46 PM
Mike in NC's Avatar
Quoted: 86 Post(s)
Liked: 71
Thanks in advance
Yes, if you look in a catalog, you can see some simple mic stands, like this one.
Just be sure not to get a short one made for a desk.
Mike (Portland, Oregon)
Spoiler!
Mike in NC is offline
post #3 of 7 Old 05-21-2020, 02:22 PM
khcoach's Avatar
Quoted: 77 Post(s)
Liked: 72
the amazon one linked above is a good one and I have it myself. However, you will also need to buy an adaptor or 2 to attach any mic's to it. I have one so i can attach my mic for Audessey for my AVR (swivels around ) and I need a different one for my UMM-6 (good alternative to the UMIK-1 for running REW) which was just a screw on adapter as the mic has it's own holder that can be adjusted.
khcoach is offline
post #4 of 7 Old 05-21-2020, 03:00 PM
CalJake's Avatar
Quoted: 86 Post(s)
Liked: 55
While not as flexible as a mic boom stand, you can also use a camera tripod for Audessey-type mics directly without requiring an adapter. The screw on most tripod mounts screws directly into the disc-type mics I've used. Even though I own several mic boom stands, this is what I do.
m. zillch likes this.
CalJake is offline
post #5 of 7 Old 05-23-2020, 05:57 AM - Thread Starter
Quoted: 133 Post(s)
Liked: 26
Thanks in advance
Thank you
I have UMIK-1, ECM8000, Emm-6 which has like holding clips with a thread, gets attached to a desk like tripod, Do I still need adapters?
post #6 of 7 Old 05-23-2020, 03:04 PM
khcoach's Avatar
Quoted: 77 Post(s)
Liked: 72
Thank you
check what thread the boom mic stand you're going to purchase has and compare to the mic holder you have. For my UMM-6 i needed just a screw on on that goes from a larger to smaller threading. for my Audyssey mic i purchased an adapter so i could then swivel around the mic so i could get it to stand at 90*.
khcoach is offline
post #7 of 7 Old Yesterday, 01:43 AM - Thread Starter
Quoted: 133 Post(s)
Liked: 26
Thank you
Thank you.
I am looking at the one on Amazon above think the one you have.
If need be where do I get adapters?
