How often should you clean your turntable stylus? - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1 of 33 Old 06-19-2020, 03:41 PM - Thread Starter
Ryan Statz's Avatar
Quoted: 1314 Post(s)
Liked: 1168
As the title asks, just wondering how often the stylus should be cleaned (i.e. after X amount of records). Still learning the basics of all of this, and everyone seems to have a different opinion as to how often one should do this. I suppose it'd be no different than asking here, but it might be useful if the answers here are vastly different than what I've seen.
Home Theatre: Marantz SR6014 | KEF Q750 | KEF Q650c | KEF Q150 | HSU ULS-15 MK2 | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is online now
post #2 of 33 Old 06-19-2020, 09:25 PM
m. zillch's Avatar
Quoted: 6780 Post(s)
Liked: 4997
Each record side of play. It takes literally 1 second of labor from a good brush, like a Discwasher SC-2*, which can be used dry for those quick cleans. There's no need for fluids most times (and I generally let nothing but distilled water ever touch my stylus and LPs so when it dries there's zero residue). Just one quick stroke from back to front, never any other direction, is all it takes. Done.
A single play of a record with a dirty stylus can theoretically harm the grooves. Better safe than sorry.
I show closeups of how quickly a stylus can get caked with dirt while playing at the end of this video:
* This design may be found from other companies too. It is made of zillions of tightly bunched brush bristles packed so densely it appears to be solid to the naked eye. It is great at getting into every nook and cranny.
P.S. This looks to be functionally equivalent: https://www.amazon.com/Pro-Ject-Clea.../dp/B003COZIQ2
Ryan Statz and CalJake like this.
m. zillch is offline
post #3 of 33 Old 06-20-2020, 01:07 AM - Thread Starter
Ryan Statz's Avatar
Liked: 1168
Thanks! I do have a stylus cleaning brush, so I'm good there - it came with the anti-static carbon fibre brush I got when I began my quest to figure out why my other turntable was intermittently popping really loud.
I've cleaned (or at least I hope I have) only the once so far, but I will certainly be more diligent now that I know I can get through a bunch of records without any issues like before (12 without any problems, just minor crackles here and there). My next step, I think, is to get a proper record cleaner.
I've only ever used distilled water to clean. I use that a lot for picture framing, and a few other things related to my art practice, so i always have a supply handy.
post #4 of 33 Old 06-20-2020, 06:39 AM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
Magic Eraser is a popular repurposed/DIY stylus cleaner. FWIW, a stylus expert suggested it.
AlexLac is offline
post #5 of 33 Old 06-20-2020, 06:51 AM
RickD1225's Avatar
Quoted: 380 Post(s)
Liked: 3449
I clean mine with an Onzow after the full album is played. I have washed every album I own and use a carbon fiber brush before playing anything.
Spoiler!
RickD1225 is online now
post #6 of 33 Old 06-20-2020, 09:19 AM
Ratman's Avatar
Quoted: 2932 Post(s)
Liked: 3009
Who is the expert?
I'm sure it can work. Just wondering about the "repurposed" part also. Does that mean "used"?
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #7 of 33 Old 06-20-2020, 09:31 AM - Thread Starter
Ryan Statz's Avatar
Liked: 1168
Huh... so you basically just lower the stylus onto the pad and keep repeating until there's nothing showing on the magic erase? Do you wet the magic erase beforehand with distilled water?
I've been using my carbon fibre brush first, then a bead of distilled water with a felt brush, and followed up with a final carbon fibre wipe afterwards before each side - but this is largely because they're records I haven't played yet, and haven't cleaned them. I think I'd just give it a brush for a bit next play, but I do need a proper cleaner to get any bit of crap out that I've missed with the rather nominal cleaning I've done.
It seems the general consensus is pretty much after each record. I'll start doing that, for sure.
post #8 of 33 Old 06-20-2020, 09:35 AM - Thread Starter
Ryan Statz's Avatar
Liked: 1168
Originally Posted by Ratman View Post
Who is the expert?
I think "re-purposed" in the context of using it for something it wasn't necessarily meant to be used (i.e. cleaning your bathroom or kitchen).
Anyone with any sense would use a brand new one, obviously
post #9 of 33 Old 06-20-2020, 09:40 AM
RickD1225's Avatar
Quoted: 380 Post(s)
Liked: 3449
I “spin clean“ all the records I buy whether they are used or brand new before playing them. Some used records I have purchased on Discogs were professionally cleaned by the seller which is very nice. I also treat all my vinyl with LAST record preservative. I have albums from the 70s that I treated and they sound like they are brand new.
Ryan Statz likes this.
Spoiler!
post #10 of 33 Old 06-20-2020, 09:43 AM
johnplayerson's Avatar
Quoted: 330 Post(s)
Liked: 102
https://www.youtube.com/watch?v=d_EDuvPCJ04
You never clean your stylus....... All you do if performance starts to degrade is put a penny on top of the head-shell, It will bore through any dirt in the way. ). Anyone remember seeing used record shops trying this tactic to make records sound better lol.
AVSCIENCE.COM. topic = 459.60
A Good amplifier requires a adequate power supply, It does not matter what the amplifier is capable of if the power supply will not provide the power required. Most amplifiers have under rated power supplies. It is up to you to make sure you get the ones that are least under rated if at all.
johnplayerson is online now
post #11 of 33 Old 06-20-2020, 09:48 AM
m. zillch's Avatar
Liked: 4997
Onzow/Zero Dust and other similar gel pad sticky/adhesion methods can easily destroy a stylus if used improperly and many people do exactly that, such as in the attached video. I'm sure it works just fine if you place it down on a fixed surface and lower the stylus onto it but hand holding it is asking for trouble because any lateral motion in your hand, just a millimeter or two, can potentially grab the needle and rip the diamond tip right off or snap/bend the cantilever.
DON'T DO THIS:
At 6m06s he doesn't lower the stylus onto the gel pad as instructed but instead hand holds the gel pad and to add insult to injury the arm is locked down. WRONG AND WRONG.
It is important gel/grip methods are only used with the gripper in a fixed, rigid position and the stylus is then gently lowered onto it. Repeat as much as you want but never move the gripper during the cleaning.
Ryan Statz and CharlesJ like this.
post #12 of 33 Old 06-20-2020, 10:22 AM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
Who is the expert?
He is known on forums as Needlestein.
Ryan got it right. Repurposed as is something that is meant for something else and people find it works for cleaning stylus. It needs to be dry and chem free.
AlexLac is offline
post #13 of 33 Old 06-20-2020, 10:27 AM - Thread Starter
Ryan Statz's Avatar
Liked: 1168
Oh dear, I would never do that hahaha I'd rather not have to buy a new stylus 2 weeks later.
post #14 of 33 Old 06-20-2020, 10:33 AM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
Dry and chem free pads. You "dump" the styli gently on the eraser in a direct angle a couple of time. I doubt you'll see a lot of evidence as it's all pretty microscopic.
I think the idea is that the eraser is dense enough to catch the dirt your styli attracted. Don't take it as a gospel, I'm sure you'll find people who think it's terrible. It's mostly an inexpensive and relatively safe way.
I'm sure there are a lot of posts and vids on it, if you want to look into it. Personally, I use the dense brush every now and then if the styli looks dirty and the pad when that doesn't help.
I'd buy that Japanese gel pad, but it's like $40 which seems like a lot.
I don't really see the point in cleaning after every side, nor to wash clean a brand new record. But to each his own.
AlexLac is offline
post #15 of 33 Old 06-20-2020, 10:48 AM - Thread Starter
Ryan Statz's Avatar
Liked: 1168
I think it's mainly because there's crap in the factory that can get all over the record. Case in point, I opened up my copy of Kraftwerk's Trans-Europe Express for the first time (it was still sealed), and there was dirt, hair, and fingerprints all over the record! I was quite surprised.
post #16 of 33 Old 06-20-2020, 10:50 AM
RickD1225's Avatar
Quoted: 380 Post(s)
Liked: 3449
^^^^Exactly why you wash new ones. Not to mention release agent residue.
Spoiler!
post #17 of 33 Old 06-20-2020, 10:51 AM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
Trans...
Europe...
Express...
It can happen, but most/many fresh sealed records are pristine. The one thing that happens often is some electrostatics from the paper inner.
AlexLac is offline
post #18 of 33 Old 06-20-2020, 10:54 AM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
I collected records for 30 years and never done that. I don't think it's a bad thing, just slight overkill.
AlexLac is offline
post #19 of 33 Old 06-20-2020, 10:54 AM
m. zillch's Avatar
Liked: 4997
There is sometimes residue from the factory even on brand new records. Also I have heard it said that the stamper machines which press the records get sprayed with a "mold release" compound so the LPs don't stick to the stamper plates and that also sometimes gets onto our new LPs.
Even just paper sleeve residue/dust can potentially be an issue.
EDIT TO ADD: DOH I'm late to the party!
post #20 of 33 Old 06-20-2020, 11:03 AM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
Too bad those still cost so much after so many years:
https://www.elpj.com/
AlexLac is offline
post #21 of 33 Old 06-20-2020, 11:20 AM
m. zillch's Avatar
Liked: 4997
They are unlistenable unless you clean up the sound, usually digitally (which many analog people hate the idea of). The thing is, no matter how much we clean a record there is always some residual dust and grime. We rely on the fact that these dust particles are extremely light and our record stylus plows right through them as easily as we might trace our finger across the top of a dusty turntable dust cover unimpeded and without any sensed resistance.
The problem is a light wave from a laser has no ability to move dust particles out of the way so instead it registers each particle of dust as a nice clean "tick" sound. These pops and ticks need to be removed in post processing.
post #22 of 33 Old 06-20-2020, 11:28 AM
m. zillch's Avatar
Liked: 4997
The laser has no way of telling what is an actually intended groove wall change and what is dirt.
post #23 of 33 Old 06-20-2020, 11:49 AM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
Thank you. I've cancelled my order
Seriously though, it makes sense now that you said it, I never really invested time in looking into it cause of the price. In a perfect situation it would have solved the many annoyances with vinyls.
I started collecting long before CDs came, and I never liked vinyls as a playable format. I don't get misty eyed over warm analog sound.
My main issue was always the surface noise. Sure, there are great pressings, but also so many mediocre to poor ones (especially if you collect avantgarde and fringe music often self-released in micro editions like me). The one thing vinyls have is the big covers. CDs sound a lot better to me, they just look like crap.
AlexLac is offline
post #24 of 33 Old 06-20-2020, 11:55 AM
Ratman's Avatar
Liked: 3009
Based on my experience on forums and a few decades of practical experience, "anyone with any sense" doesn't equate to "common sense". Kind of like drinking/injecting bleach to prevent Covid19.
Isn't there a cleaning substance on the pad? Wouldn't that leave a residue?
EDIT:
https://www.wired.com/2015/09/whats-...-magic-eraser/
Ratman is offline
post #25 of 33 Old 06-20-2020, 11:58 AM
Ratman's Avatar
Liked: 3009
He is known on forums as Needlestein. .
An expert? Perhaps. I doubt it.
Ratman is offline
post #26 of 33 Old 06-20-2020, 12:03 PM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
What do you doubt about it?
AlexLac is offline
post #27 of 33 Old 06-20-2020, 12:05 PM
Ratman's Avatar
Liked: 3009
Everything. How is he/she an "expert". There are experts on AVSForum too.
Ratman is offline
post #28 of 33 Old 06-20-2020, 12:11 PM
AlexLac's Avatar
Quoted: 316 Post(s)
Liked: 244
He is most famous for his retipping service that he has been doing for many many years.
Here's an example:
https://www.ebay.com/itm/Cartridge-R...1/183981132767
AlexLac is offline
post #29 of 33 Old 06-20-2020, 12:21 PM - Thread Starter
Ryan Statz's Avatar
Liked: 1168
EDIT:
You mean those homemade Comet capsules I've been making these past several weeks are doing nothing?
Oh probably. Might not be too terrible if you're using it dry for this purpose, though? I'm sticking to the stylus brush I already have rather than rush out to buy a doomsday prepper stock's worth of magic erasers
Ratman likes this.
post #30 of 33 Old 06-20-2020, 12:24 PM
Ratman's Avatar
Liked: 3009
What else made him "famous"?
Ratman is offline
