System layout advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-21-2020, 08:01 AM - Thread Starter
Liked: 0
I currently have everything running off a marantz SR 5011. I’m thinking of using a pair of M1-s as front heights speakers for
Possible Atmos. Currently I have a B&W S2 center channel, a pair of CM9s as my main fronts and a pair of 600’s as the rear surround speakers. Would it be wise to use the M1’s as front heights to create a 5.1.2 setup for at most? Or utilize those as surround backs for a 7.1?
espfdps is offline
post #2 of 5 Old 06-21-2020, 12:21 PM
gajCA's Avatar
Quoted: 10183 Post(s)
Liked: 7215
In a smaller room 5.1.2, in a larger room, 7.1.
Geoff A. J., California
gajCA is online now
post #3 of 5 Old 06-21-2020, 12:22 PM
RayGuy's Avatar
Quoted: 3579 Post(s)
Liked: 3395
You can go either way, but do you have the correct layout for 7.1?
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #4 of 5 Old 06-21-2020, 05:19 PM - Thread Starter
Liked: 0
Currently I can’t do a 7.1 but will be moving my system to a different location when my basement is done.
espfdps is offline
post #5 of 5 Old 06-22-2020, 08:21 AM
RayGuy's Avatar
Liked: 3395
Set it up as 5.x.2 (temporarily) and see how you like it. Depending on how your side surrounds are going to be placed, you may not even miss the additional two rear surrounds. Getting some height information might be a big improvement, or you might be underwhelmed. I've seen both reactions here.
RayGuy is offline
