Check my Atmos angles >> - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-23-2020, 05:46 AM - Thread Starter
platinum00's Avatar
Quoted: 27 Post(s)
Just want to confirm my height locations and angles before install. I think the ideal angle is 45 and this should be pretty close? A perfect 45 I cant do because of mounting locations in the ceiling.
The picture is not to scale.
platinum00 is online now
post #2 of 5 Old 06-23-2020, 08:34 AM
sdurani's Avatar
Quoted: 7890 Post(s)
Liked: 7084
45 degrees elevation is easy to figure out: measure from your ears to the ceiling, that same distance forward & rearward of you is 45 degrees elevation. Placement doesn't have to be exact, just get close. Spread the height speakers roughly the same width apart as your front L/R speakers.
Sanjay
sdurani is offline
post #3 of 5 Old 06-23-2020, 08:37 AM - Thread Starter
platinum00's Avatar
Quoted: 27 Post(s)
Right.. so my measurements for 42.5 should be OK then correct? I cant do 45's
post #4 of 5 Old 06-23-2020, 08:48 AM
sdurani's Avatar
Liked: 7084
42.5" will be fine.
Those 4 Atmos locations are close enough to the DTS:X height locations that your placement will serve both formats.
Sanjay
sdurani is offline
post #5 of 5 Old 06-23-2020, 10:07 AM - Thread Starter
platinum00's Avatar
Quoted: 27 Post(s)
OK.. thank you for the confirmation.
