Why should I cross my full-range speakers at 80hz in 2-Channel or Home Theater - AVS Forum | Home Theater Discussions And Reviews
 11Likes
  • 2 Post By Ratman
  • 4 Post By Alan P
  • 2 Post By Ratman
  • 2 Post By craig john
  • 1 Post By craig john
post #1 of 15 Old 06-24-2020, 09:29 AM - Thread Starter
CZ Eddie's Avatar
Quoted: 139 Post(s)
Liked: 74
I'm a DIY'er and see lots of talk about... "Just build it small because you're going to cross it over at 80hz to a subwoofer anyway".
This makes no sense to me, so I'm wondering what technical info I'm missing out on.
If you have the space for large monkey-coffin full-range speakers AND subwoofers, then why not have both and run the main [large] speakers full-range along with the sub?
Assuming the speakers can handle it of course.
I think I read somewhere that Dr Geddes configured his home theater that way.
Though his main speakers were not exactly true full-range capable.
"The boom is dead, long live the bass"
CZ Eddie is offline
post #2 of 15 Old 06-24-2020, 09:30 AM - Thread Starter
CZ Eddie's Avatar
Quoted: 139 Post(s)
Liked: 74
Originally Posted by CZ Eddie View Post
I think I read somewhere that Dr Geddes configured his home theater that way. [full range main speakers + full range subwoofers]
No, I didn't read it. I watched the video.
I certainly don't want my subwoofers running full range.
But I can't think of any reason not to run my main speakers full-range.
CZ Eddie is offline
post #3 of 15 Old 06-24-2020, 10:07 AM
Ratman's Avatar
Quoted: 2932 Post(s)
Liked: 3009
The way I setup/configure my system....... If I like the sound, I don't care what "experts" or anyone else says.
Jonas2 and leecreek like this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #4 of 15 Old 06-24-2020, 10:15 AM - Thread Starter
CZ Eddie's Avatar
Quoted: 139 Post(s)
Liked: 74
Hahah, I "hear" you.
But if you have the ability to decide that you have fully vetted the pros & cons of a particular setup after just a few minutes of listening, then you're an audio God!
CZ Eddie is offline
post #5 of 15 Old 06-24-2020, 10:18 AM
Alan P's Avatar
Quoted: 7115 Post(s)
Liked: 6986
Three reasons come to mind:
1) Speakers must be placed in the room where they provide the best imaging/soundstage and these locations are rarely the best location for bass reproduction.
2) Cancellations in the lower octaves caused by the interaction between the subwoofer(s) and speakers
3) Unless you plan on powering your mains with an insane amount of wattage, no "large" speaker can do what a subwoofer can do
Sony XBR75X940D | Denon X4500H | Nvidia Shield | Synology NAS [52TB] | miniDSP 2x4 HD | TiVo Roamio
PSA MTM210 [x3] | Polk LS/fx [x4] | Klipsch RB61 [x2] | Crowson LvL3 MA [x2] | PSA TV42 Ipal [x2]
Alan P is offline
post #6 of 15 Old 06-24-2020, 10:23 AM
tcoble33's Avatar
Quoted: 28 Post(s)
Liked: 30
All three of these are right, but #3 is 1,000% right.
tcoble33 is offline
post #7 of 15 Old 06-24-2020, 10:26 AM
Ratman's Avatar
Liked: 3009
No... but a few hours of changes and evaluation allows me to sit at the right hand of one.
eljaycanuck and Jonas2 like this.
Ratman is offline
post #8 of 15 Old 06-24-2020, 10:34 AM
MrBobb's Avatar
Quoted: 320 Post(s)
Liked: 148
Is a guideline, not an hard rule.
Paul at PS audio, favor a sub for 2 channels but never mentions crossing the mains.
^Ya, what he says, if it sounds good to you, leave it there never mind what everybody else say.
MrBobb is online now
post #9 of 15 Old 06-24-2020, 10:41 AM
smdelaney's Avatar
Quoted: 271 Post(s)
Liked: 526
If you run a sub alongside VERY bass capable mains there is no reason to follow the 80hz guideline, instead you can still take advantage of your mains AND the sub by crossing over lower...maybe @ 60 all depending on the range of your mains. Let the sub do the heavy lifting.
If this is a 2 channel setup for music and not home theater then just go with the big @ss, bass capable mains and skip the sub.
"You keep using that word...I do not think it means what you think it means."
-Steve-
TCL 55R617, Denon AVR-X2400H, Philips BDP-7502, Onkyo DX-C390, (2) HEOS 3HS2's,
Cambridge Soundworks Ensemble (FR/FL), MC150 (C), S100 (SR/SL), KLH E-12DB (SW)
smdelaney is offline
post #10 of 15 Old 06-24-2020, 11:07 AM
craig john's Avatar
Quoted: 1697 Post(s)
Liked: 2015
https://www.youtube.com/watch?v=L4Bm123cKAM
Earl Geddes has never understood Bass Management.
sdurani and RUR like this.
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence.
My System (Edited Feb. 2020 to add 4K and Atmos updates)
craig john is offline
post #11 of 15 Old 06-25-2020, 07:30 AM
Quoted: 593 Post(s)
Liked: 300
What do you consider actual full range speakers?
80Hz is a guideline and a better one might be double the f3 point (where the speakers dip -3dB) for bigger speakers.
A sub gives you options and can solve problems mentioned earlier in the thread.
Leeliemix is offline
post #12 of 15 Old 06-25-2020, 08:53 AM
craig john's Avatar
Liked: 2015
Great post Alan! I will just add a little more detail to #3 .... relieving the amps of of the burden of the bass frees up wattage in the main channels that can more efficiently be used to drive the speakers. Every octave of extension requires a doubling of driver excursion, which requires a doubling of power output. To go from 80 Hz to 40 Hz requires a doubling of power. To go from 80 Hz to 20 Hz requires a quadrupling of power. Subwoofers, with their larger and dedicated power amps, can dig deeply much more efficiently. Adding powered subwoofers can free up all that amp power to drive the speakers, and allows the entire *system* to play back louder with lower distortion.
Bottom line, it makes a lot of sense to use "bass-limited" mains in conjunction with Bass Management and powered subwoofers. One more advantage is that the $$$ saved on large, expensive towers can be re-directed towards better, smaller speakers, or more and/or better subwoofers.
Craig
Alan P likes this.
Lombardi said it:
post #13 of 15 Old 06-25-2020, 09:19 AM
teetertotter's Avatar
Quoted: 64 Post(s)
Liked: 45
I use the AVR Audyssey microphone, for calibrating the room speakers. With my set-up and placement of MATCHED front speakers, the crossovers are 60HZ across the board, including the surrounds.
I use the LFE subwoofer input and set the subwoofer at half gain/volume, before speaker calibration. After calibration, I reduced the gain/volume to 1/4, for my overall listening. I have a button on the remote for DD surround for Netflix movies, and the music button is set for Multi-channel mp3 music.
Since I have this Audyssey calibration with my AVR, 60HZ crossover, it is where it is at.
TV: TCL 55" 4K UHD HDR w ROKU
DENON AVR-S910W, 7.2, HDMI 2.0a, 4K UHD HDR, Upscaling, Atmos, Wi-Fi, etc. [2016]
KLIPSCH: L/R: R-51M - Ctr: RP-400C - Sub: R-100SW - POLK S-20 Surround
SPKR Wire:Windy City Wire - 16ga, 2 Cond, Twisted Pair, Shielded, Jacketed [USA]
HDMI: VANCO - 4K, 18Gbps, 2.0b, Certified --- [AT&T - Directv Sat. & DSL 100Mbps]
teetertotter is offline
post #14 of 15 Old 06-25-2020, 07:35 PM
RayGuy's Avatar
Quoted: 3580 Post(s)
Liked: 3397
Bottom line, use the right tool for the job. Subs are created to reproduce bass. Tower speakers reproduce bass as a side-gig to reproducing all the rest of the frequencies.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #15 of 15 Old 06-25-2020, 07:50 PM
MalVeauX's Avatar
Quoted: 39 Post(s)
Liked: 36
Heya,
Crossing over around 80hz is often to help with localization in movies (home theater) in addition to offloading a lot of energy and size needs and placement needs of a full range speaker set to do the same thing. It sounds like a great idea to skip the sub and just use full range mains if possible, but that assumes placement is excellent in the room and the bass range is not just a bunch of nulls that you cannot fix, since those bass ranges are placement dependent and you're seeing the room response, not so much the speaker's ability to create those frequencies at whatever SPL. So a sub helps since you can place it more ideally without destroying your imaging with weird placement of the mains. You can cross over lower if you want. Or higher if you want. It's all about how it works out in terms of room response and covering up any nulls at the listening positions. It may not matter at all for a lot of music that doesn't have a natural instrument or synthetically produces tones that drop as low as 20~25hz. But it matters a lot for movies/home theater where you will very often have 20hz~60hz tones on the regular, and more and more often with newer content.
Anyhow, cross them over where you wish based on listening position room response nulls to bass frequencies.
Very best,
MalVeauX is offline
