Official Logitech Harmony 650/600 remote thread - Page 50 - AVS Forum | Home Theater Discussions And Reviews
 44Likes
post #1471 of 1921 Old 09-12-2015, 04:31 PM
Dropkick Murphy's Avatar
Quoted: 75 Post(s)
Liked: 90
Originally Posted by ericole View Post
1. the remote will not power it on or off with the activity of "listen to music". BUT the remote IS set up to control that function correctly as I can get the on-screen menus to power it on and off
2. the "skip" buttons will not work to change tracks. I can change them with the number keys (up as far as I have numbers) and again with the on-screen menu. But not with the control button that should do it (neither forward or backward)
So the remote is obviously able to control the CD changer b/c it has the functions programmed in. But for some reason I can't use the buttons I should (the FF/RW buttons work just fine, just not the skip/back buttons), and the activity controls (even after doing the "help" function) won't do the power.
I'm new with the remote (had it sitting around for over 3 years-LOOOONG story) and just can't figure out what the deal is.
Any help would be appreciated.
1. Are you sure that your CD player has power commands? I only ask because many older CDP's do not, you have to power them on manually and then the remote controls all functions. I'm not sure what you mean by "on screen menu's"
2. Are there commands on the Harmony for CHAPTER NEXT/PREV or NEXT/PREV TRACK? those are probably the correct ones for track skip.
Dropkick Murphy is offline
post #1472 of 1921 Old 09-15-2015, 06:32 PM
ericole's Avatar
Yes, it has power commands b/c it has a remote with it that turns it on and off. And the "on screen menu" has a command for it. By that "on screen menu" I mean the screen/display at the top of the remote. See the picture attached. In there you can dig into ever command that the Harmony remote is programmed with for your devices. ALL of the things I'm having issues with as activity commands are listed, and do work, in the on screen menu.
Yes, there are those commands on the remote - in the on screen menu. Again, all functions work that way, but skip track should work with the buttons on the remote. Why would FF and RW work but not the skip track. I wish you could actually see, on the computer app, the actual commands that the Harmony has programmed in, and where they are working. What would be awesome is a Simulink-type interface where all of the functions are listed, and you could simply drag them to the button you wanted to associate with them. At that point, a sync would make it happen. That would allow you manually fix any errors the remote is having. Without that manual capability, I'm having a hard time figuring out how to fix these problems.
Name:	Screen Shot 2015-09-15 at 7.31.35 PM.png
ericole is offline
post #1473 of 1921 Old 09-15-2015, 06:45 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
Been a while since I reprogrammed either of my similar Harmony 650/670 remotes.
But, IIRC ... you can re-program any button. They can also be trained directly from existing remote.
This would be because Harmony has a few errors in that profile. I suppose the other way would be to let them know and see if they can fix it on their end. You would then delete and re-add the device.
Epson 8350 3LCD Projector (96" @ 1080p) ~ Panasonic 850u 46" Plasma TV (1080p)
Onkyo TX-sr607 AVR ~ Cisco 8742hdc DVR (Spectrum) ~ Panasonic BD60 Blu-Ray Player
AppleTV-4 (iTunes,Plex,MA,Asphalt-8) ~ Simple Control HA ~ Alexa Echo Plus w/Hub
Harmony 670 Remote ~ HTPC (Kodi/Win10-64) Media-Server ~ Synology DS412+ 16tb Raid-5 NAS
Polk Audio Monitor Series-II CS-2 Center, 60 pair, three 40's / PSW-505 12-Inch Sub = 6.1
Tesla1856 is offline
post #1474 of 1921 Old 09-15-2015, 07:52 PM
ericole's Avatar
button programming
I don't know how to individual program a button - I'll look in my pdf manual and see if that is mentioned. I did to the training from the remote - that was the first fix I attempted. It said it trained it, but it hasn't fixed the power issue. I didn't try to train the skip/back buttons though.
How exactly do I let Logitech know so they can fix it??
ericole is offline
post #1475 of 1921 Old 12-03-2015, 07:57 PM
Philm63's Avatar
Quoted: 30 Post(s)
Liked: 9
For the 650 (don't have it yet, just askin'); when you replace the batteries, will there be a loss of any programmed functions? Or is the programming of activities and such independent of battery power?
I see a post or two in this thread mentioning dropping the remote and having it "reset" - does this mean it looses some (or all) settings, or is it that once you program it, it's good to go whether or not it has batteries in it?
Living Room: Sony XBR55X850B | Denon X2000 | L/R - Chane A1's | Gaming - Xbox One and 360
Basement: Denon 4520CI | L/R - Chane A5rx-c | Oppo 103D | Subwoofer - PSA S3000i
Philm63 is offline
post #1476 of 1921 Old 12-03-2015, 08:07 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
Originally Posted by Philm63 View Post
1. For the 650 (don't have it yet, just askin'); when you replace the batteries, will there be a loss of any programmed functions?
2. Or is the programming of activities and such independent of battery power?
1. no
2. yes
post #1477 of 1921 Old 12-03-2015, 09:30 PM
Philm63's Avatar
Quoted: 30 Post(s)
Liked: 9
Is the new MyHarmony software as capable as the older 7.7 version software? Example; say I'd like to be able to set the backlight to shut off after 1 second - can I do this with the new software, or can even the old software do this? (I'm sure there are plenty of tweaks I'll come up with once I start playing with it... just would like to know if the new software will allow the same programming flexibility as what it seems the old software does.)
<EDIT> After reading this thread front to back, it would appear the old software would not work with a new 650 as I do not have an old account (first-time Harmony owner - assuming I get one for xmas, that is...) MyHarmony has seen some upgrades making it all I should need to get the 650 to do what I need it to do. Works for me!
Philm63 is offline
post #1478 of 1921 Old 12-12-2015, 08:49 AM
JGM
JGM's Avatar
Quoted: 162 Post(s)
Liked: 100
All the harmony remotes keep programming intact across battery changes. I am not sure how this is done (capacitor?) or how long you could leave the batteries out before risking loss. But normal battery changes are no problem.
When I drop my 650 it sometimes resets to "first use" state -- it keeps all programming but wants you to go through the little built-in "welcome to your remote" tutorial, which is a big pain and either winds up with everything out of synch. I thought it was just mine (I bought a refurb), so it's interesting to hear that it has been mentioned here. Is there any solution for the problem?
JGM is offline
post #1479 of 1921 Old 12-12-2015, 09:14 AM
oryan_dunn's Avatar
Quoted: 193 Post(s)
Liked: 135
I'm sure it is just non-volatile flash storage.
My guess is when it's dropped, the batteries disconnect for just a split second. Perhaps make sure that the springs are tight. The other thing it could be is a bad solder joint. I'm not sure what else physical trauma could affect that would cause it to behave as if you'd just replaced the batteries.
Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime
oryan_dunn is online now
post #1480 of 1921 Old 12-13-2015, 11:30 AM
Thread Ender
WS65711's Avatar
Quoted: 544 Post(s)
Liked: 389
I just bought a Harmony 650 this morning at Sams. Running through the setup, it appears that the Oppo BDP-103 is not supported? Every time I try to add the device it tells me I am adding a "Home Theater System" and indicates that it may or may not work because there are multiple ir codes. I tried BDP-93 with the same result. Is this BluRay player not supported?
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
post #1481 of 1921 Old 12-13-2015, 12:03 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
So you take a few minutes to add it so we all can use it. Isn't that how it works?
Not sure who (Harmony or a user) added my system's Panasonic BD-60 BluRay player, but they left out a few buttons. Buttons like VieraCast (apps) and 4 color buttons (RGBY). I think because there is no equivalent "hard buttons" on remote. So, I added them (by training from original remote) to the Device and assigned them to small-LCD-display.
I'm still using Windows-based software.
post #1482 of 1921 Old 12-13-2015, 01:12 PM
mdavej's Avatar
Quoted: 3104 Post(s)
Liked: 1408
It is supported. It's a home theater device because, unlike most BD players, it has inputs and multiple addresses. Just let the software do its job. If it bothers you, keep picking different Oppos until you get one you like. All the codes are the same.
mdavej is online now
post #1483 of 1921 Old 12-13-2015, 04:34 PM
Thread Ender
WS65711's Avatar
Quoted: 544 Post(s)
Liked: 389
Ok, thanks for the helpful information. Not being familiar with any other equipment that Oppo may or may not produce, I was thinking that the app was mis-identifying the Blu-Ray player. And the image the app displayed looked to be some HTIB or something....
Blu-rays & DVD's
WS65711 is offline
post #1484 of 1921 Old 12-15-2015, 01:15 PM
nola4130's Avatar
Quoted: 27 Post(s)
Hi, I searched through this thread and could not find my exact issue. I recently purchased a Samsung Ju7100 which replaced my 2 yr old Samsung TV (non smart TV). Everything is ran into my Pioneer VSX-1021K receiver and to the TV's ARC input (HDMI 4). Everything works find when I click "Watch TV", but 30 seconds later, my receiver changes to TV input which is used for ARC. I do have HDMI Anyconnect turned on because that is only way for me to get sound from the TV to my receiver when using the TV's Smart function. I did change the start up order so that the TV comes on last, but it made no difference. Also, the activities are setup to not change the HDMI input on the TV.
Any help will be appreciated.
nola4130 is offline
post #1485 of 1921 Old 12-15-2015, 01:53 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
Obviously, I keep HDMI-CEC off on my two Harmony controlled systems.
When I helped my brother setup his Onkyo-Panasonic Plasma (non-Harmony controlled) I was surprised to discover we had to turn on HDMI-CEC to get ARC to work. Got me thinking about the ramifications is he ever wanted a Harmony Remote as well.
Seems like Harmony would need a option switch for that on each device. Well, seems it's not there:
https://support.myharmony.com/en-us/...g-hdmi-and-cec
But remember that ARC is just a trick to eliminate an extra cable (usually SPDIF optical or coax) from TV back to the Amp (for TV generated content ... either ATSC-Tuner or Smart-Apps). So I think you just set-it-up like before ARC existed ...
- Turn off HDMI-CEC on all components
- Install SPDIF cable
- Program Amp to use SPDIF input
- Setup TV-Smart-Apps as a new Activity
post #1486 of 1921 Old 12-15-2015, 02:13 PM
nola4130's Avatar
Quoted: 27 Post(s)
Thanks. I was afraid of that. I'm going to mess with the order of things and the delays and see if something changes. I'll report back.
nola4130 is offline
post #1487 of 1921 Old 12-15-2015, 02:45 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
Sounds good. Addtionally ...
If you have no cable or satellite STB (meaning you only use TV tuners to generate TV content) I don't think you will even need to setup another Activity. You could just setup Amp to use SPDIF for audio always (and just use Watch-TV Activity).
post #1488 of 1921 Old 12-17-2015, 08:53 AM
Dave in Green's Avatar
Quoted: 3835 Post(s)
Liked: 3034
About 15 years ago I bought a pretty expensive universal remote (don't even remember the brand). It was such a royal pain to program and use that I gave up after a few weeks and went back to multiple remotes. Since then I've continued to assume that universal remotes were not even worth considering.
Over the years my system expanded to include six remotes and I just recently started wondering how much universal remote technology had improved. After browsing this forum I was impressed with what Logitech has done with the Harmony series and figured the 650 was the sweet spot in terms of capabilities for the price, so I bought one last week.
After breezing through the setup process and having used it for a week now, I am mighty impressed. The 650 is simple to use and does everything I need on a daily basis. I do keep the other remotes nearby for the rare occasions when I want to dig deep into a device's menu. But having just one remote for 99% of my needs sure makes life easier.
If anyone is holding back on buying a universal remote because they had a bad experience like mine many years ago, I highly recommend giving the 650 a chance to demonstrate how far universal remote technology has improved in recent years.
Dave in Green is online now
post #1489 of 1921 Old 12-17-2015, 02:22 PM
KBMAN's Avatar
Quoted: 405 Post(s)
Liked: 207
HEY GUYS...new 650 owner ($50 at BestBUY!)...
One question (for now)...Can you program this remote to have the Master Volume (from the AVR) to work, no matter what device is selected??? Thanks in advance
Basically just want my Marantz Preamp to have volume commands at all times....
KBMAN is offline
post #1490 of 1921 Old 12-17-2015, 02:37 PM
KBMAN's Avatar
Quoted: 405 Post(s)
Liked: 207
KBMAN is offline
post #1491 of 1921 Old 12-17-2015, 02:58 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
Yes. That's how I have mine setup.
I think it's just a matter of having Marantz Amp a member of all Activities. The Activity Wizard should also lead you down that path.
post #1492 of 1921 Old 12-17-2015, 03:03 PM
mdavej's Avatar
Liked: 1408
I could have sworn I just answered this exact same question in another thread. No, you can't have volume punch through in device mode on Harmony. Activities are required for that.
post #1493 of 1921 Old 12-17-2015, 04:37 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
Maybe not, but I always end any Device Mode access with one last button ... my current Activity (what way the LCD and LCD buttons are correct for my current Activity).
post #1494 of 1921 Old 12-17-2015, 05:22 PM
mdavej's Avatar
Liked: 1408
Point is, devices on Harmony don't have punch thru. Workaround is to learn AVR vol to vol keys on every device, as I said in KBMAN's other thread. Switching back to the activity is using the activity's VPT, not the device's. As soon as you return to your activity, you're no longer in device mode.
Most other universal remotes DO have global VPT. If that's what KB requires, he should get one of those remotes. Otherwise, he needs to learn how to program and use activities.
post #1495 of 1921 Old 12-17-2015, 05:27 PM
mdavej's Avatar
Liked: 1408
Point is, devices on Harmony don't have volume punch thru. Workaround is to learn AVR vol to vol keys on every device, as I said in KBMAN's other thread. Switching back to the activity is using the activity's VPT, not the device's. As soon as you return to your activity, you're no longer in device mode. True, it's only one extra button press, but isn't true VPT.
Most other universal remotes DO have global VPT. If that's what KB requires, he should get one of those remotes. Otherwise, he needs to learn how to program and use activities. Old habits from device based remotes die hard.
post #1496 of 1921 Old 12-17-2015, 11:38 PM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
I would guess so.
In both of my Harmony Remotes ... I'm always (99% of the time) in an Activity. The main buttons (Watch TV, Play a Disc, Listen to Music, etc.) ... all Activities. Using normal setup procedures, you would have to go out of your way to NOT use Activities. Macros are another nice feature.
If you are in an Activity and find yourself going to Device Mode to press a button ... better to just add it to Activity's LCD screen. It can be a button from any Device.
Also, any button that is missing from a Device, can be custom trained (from original remote) and added to Device in Harmony. If there is no hard-button for it on Harmony, it can be added to Device's LCD screen.
post #1497 of 1921 Old 12-18-2015, 02:22 AM
mdavej's Avatar
Liked: 1408
I agree with all of that 100%.
post #1498 of 1921 Old 12-18-2015, 06:33 AM
eg1
eg1's Avatar
Liked: 0
Just ordered a 650. I somehow managed to lose my One a couple of days ago. I imagine I'll probably find it right around the time the 650 arrives ...
eg1 is offline
post #1499 of 1921 Old 12-25-2015, 04:36 PM
Liked: 0
Hi guys. I can't find a place where my question's already been addressed, so I'm going to throw it out there. If I missed the answer, please feel free to direct me to the correct page for it.
I've had a Sony HT-CT150 sound bar for a long time. Works perfectly. I'd had one LGTV, and we recently upgraded to a new 65uf8500. I'm loving the tv, but the interface has one quirk that's making me crazy, and I'm hoping I can get my Harmony 650 to fix it.
Audio output switching isn't available on any of the main buttons on the tv remote. To get to those settings, I need to hit a button on the tv remote, open a menu of sorts, THEN open the Advanced option from there, switch to the audio setting (lots of other setting options in that menu, like picture), THEN get to the Audio output setting and choose what I want. So, the setting is, like, 3 levels in.
I can't find a way to find that command, even using macros, since it's so deeply in there - but I'd really like to switch from my soundbar to my headphones (they're RF from a 3.5" input - no bluetooth available - don't get me started!.... UGH!), then back to the soundbar when I'm done.
Setting an action won't do it, because even to set back to listening through the soundbar, although it sets the soundbar correctly - the tv doesn't know to talk to it unless I reset it's internal output setting. None of this seems automatic - it's a function of the damned thing wanting me to physically plug in the 3.5" cable in the back of the tv EACH time I use it, and I simply won't do that.
So.... anyone know how I can get the Harmony to know what functions may be deep inside the tv, when it's not a main button on the remote? Thanks!
SGans is offline
post #1500 of 1921 Old 12-26-2015, 03:34 AM
Tesla1856's Avatar
Quoted: 295 Post(s)
Liked: 106
Create 2 macros ... one to turn it on, another to turn it off. For instance ... I have 3 macros that load 1 of 3 different saved (brightness and color) Profiles on my projector (I call them Day, Dusk, and Night) ... so I know you can deep dive into menus.
You can add (TV menu) cursor buttons or whatever to each macro.
Reply Remote Control Area
