EFC codes for comcast remote and Atlas 1056B01 with LG 47LN5700 and Technics SA-DX930 reciever - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-30-2013, 10:42 AM - Thread Starter
e_mr's Avatar
Does anyone have EFC codes for either of these remotes and LG47LN5700, [user manuals]? These comcast codes mostly work but Flashback doesn't work, tried both back codes.
Also EFC codes for an old Technics SA-DX930. All that works currently is power and volume, which is okay but would like to control surround and function at the least.
Finally some questions:
1. Also where are these codes found?
2. Is it JP1 cable plus RemoteMaster?
3. I found a schematic for a diy serial JP1 cable which I could do today, but no computer with a serial port. Is there a schematic for a diy usb?
e_mr is offline
post #2 of 5 Old 12-30-2013, 11:14 AM
mdavej's Avatar
Quoted: 2996 Post(s)
Liked: 1344
1. JP1 database, remote central. LG documents (sometimes), harmony database, trial and error.
2. Yes
3. Building a JP1.3 serial cable from scratch is hard, and building a USB one is even harder. Just get one of these from ebay ($7.65 shipped).
http://www.ebay.com/itm/330809610323
Looks like the codes in that post may have run together. Just use the first 5 digits. Flashback is probably Q.View which is 00247.
What setup code are you currently using for the Technics?
mdavej is online now
post #3 of 5 Old 12-30-2013, 01:31 PM - Thread Starter
e_mr's Avatar
Thanks! 00247 worked for flashback. 31308 for technics. Do you have any links for those db's?
Thanks also for the JP1 cable link, I was finding them for around $30+
e_mr is offline
post #4 of 5 Old 12-30-2013, 02:17 PM
mdavej's Avatar
Liked: 1344
All JP1 files are below. You need to download and install Remote Master and associated files (RDFs, Maps and Images) from that same site to be able to read the files. You usually don't find an exact model match, but something of the same make and vintage usually works fine.
http://hifi-remote.com/forums/dload.php?action=category&cat_id=4
For your Technics, you can try here: http://hifi-remote.com/jp1/lookup/, search by setup code for Audio 1308 (the leading 3 means Audio), then click EFCs for an EFC list. Or try the codes below which came from a similar model (I'm guessing):
Code:
0    60578
1       60466
2       60594
3       60530
4       60658
5       60434
6       60562
7       60498
8       60626
9       60450
vol up  60734
vol down        60862
mute    60790
channel up      60438
channel down    60566
power   60806
TV (Tape Monitor)       60755
Cable (TV/DVD/DSS)      60867
VCR     60739
Tuner   60787
DVD (CD)        60691
Surround On/Off 60726
Surround +      60686
Surround -      60814
Center +        60745
Center -        60873
Dolby Test      60757
Direct Tuning   60459
FM Tune +       60507
FM Tune -       60635
Band    60447
>=10 60443
Discrete On     60742
Discrete Off    60870
post #5 of 5 Old 01-06-2014, 11:08 PM - Thread Starter
e_mr's Avatar
Thanks, those worked and I was able to find them the codes for the atlas remote.
e_mr is offline
Reply Remote Control Area
Lg Electronics 47ln5700 47 Inch Led Lcd Hdtv With Smart Tv
