Wired IR vs. Emitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-30-2013, 04:25 PM - Thread Starter
jwhn's Avatar
Quoted: 653 Post(s)
Liked: 163
Hi,
Sorry if this question has been asked. I searched quite a while but didn't find the exact answer I need.
I have a Yamaha RX-V650 receiver that has remote in/out jacks. The manual describes how to use these to control zone 2.
I have an IR repeater / extender unit and I can control the basic functions of the Yamaha by placing the IR emitter on the front of the receiver. I can then control the unit with the cabinet doors closed.
Can I instead directly connect the IR repeater unit with the remote in / out receiver using a male/male 3.5 connector?
I am not trying to use the zone 2 feature.
Any help would be appreciated.
jwhn is offline
post #2 of 2 Old 12-31-2013, 11:17 PM
Glackowitz's Avatar
Yes use the wired input, gives a better control option over an emitter
should be a Mono mini to mono mini 3.5mm cable
Glackowitz is offline
Reply Remote Control Area
Yamaha
