Which Remote? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-02-2014, 09:56 AM - Thread Starter
Jon Middleton's Avatar
Quoted: 203 Post(s)
Liked: 145
I have an Oppo 103, a Sony HW 55ES, Direct TV, and a Rotel RSP 1066. I'd like to have one remote to control the basic functions of all four. Inexpensive and simple is good.
Jon Middleton is offline
post #2 of 5 Old 03-03-2014, 09:38 AM
insync44's Avatar
Quoted: 25 Post(s)
If they are out in the open get the 650 (usually about $49.99) on sale. If in a cupboard the best bet is the Smart Contro (I prefer 900 bit its discontinued). Personally, I don't like a Wifi remote like the Ultimate and Smart. If you have a "flaky" connection with the router, you have problems. My 650 and 900 don't depend on Wifi connections. Just my opinion.
insync44 is offline
post #3 of 5 Old 03-03-2014, 01:14 PM
belts4jose's Avatar
http://www.logitech.com/en-us/harmony-remotes
Any of these will work.. I prefer the 900 which is discontinued but you may be able to find one on eBay or Amazon
belts4jose is offline
post #4 of 5 Old 03-03-2014, 01:57 PM
mdavej's Avatar
Quoted: 3068 Post(s)
Liked: 1393
Any cheap learning remote like the RCA RCRP05BR ($8) will also work, if you still have your Rotel remote to learn from (or get a JP1 cable). Very few cheap remotes still have those old Rotel codes built in. Harmony does have Rotel codes of course, probably URC too, but they can get expensive.
mdavej is online now
post #5 of 5 Old 03-03-2014, 06:44 PM - Thread Starter
Quoted: 203 Post(s)
Liked: 145
Reply Remote Control Area
Oppo Bdp 103 3d Blu Ray Player , Sony Vpl Hw55es 3d Projector
