Extending Harmony IR mini blasters - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #151 of 158 Old 09-02-2018, 07:18 AM
azz7686's Avatar
Quoted: 278 Post(s)
Liked: 125
I'm 99.9% sure the tip is positive, as for easier IDK thats usually personal preference on the design and know how of consumer!
Spoiler!
azz7686 is offline
post #152 of 158 Old 01-19-2019, 03:06 PM
RonBonnell's Avatar
Quoted: 35 Post(s)
It would be nice if Logitech would actually give the length of this device in their specs so I could figure out if I need to have an extender. Does someone have the approximate length? Does any IR blaster work with the hub or do I need to use the specific Logitech blaster?
RonBonnell is online now
post #153 of 158 Old 02-14-2019, 09:22 PM
originalsnuffy's Avatar
Quoted: 27 Post(s)
So I connected one of the two 3.5 mm outputs to the receiver portion of an IR repeater block. That essentially shut down the IR repeater.
Any thoughts on what might be going on?
I have other questions but this seems like a good spot to start.
originalsnuffy is offline
post #154 of 158 Old 02-16-2019, 09:15 PM
Quoted: 12 Post(s)
Liked: 3
The receiver portion of the IR block is for a IR receiver. The 3 conductor 3.5mm plug on a IR receiver is IR, +V and GND. You probably shorted out +V to GND.
stevestms is offline
post #155 of 158 Old 02-17-2019, 06:57 AM
BJBBJB's Avatar
Quoted: 118 Post(s)
Liked: 36
I cut off the plug and stripped the ends of the hub output and attached the individual wires to a xantech ir repeater. It works great.
I do not recall the wiring layout of the hub output, but I found it online somewhere, ie. color of wire and which was ground, etc.
BJBBJB
BJBBJB is offline
post #156 of 158 Old 04-14-2019, 10:19 AM
arsenalgunner's Avatar
Quoted: 16 Post(s)
For anyone interested in extending the IR blasters, this item from Amazon works to extend over Cat5e/6:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I tried extending over 50ft with a 3.5mm mono cable like the OP and the signal was too weak to be worthwhile.
Hope this helps someone out.
arsenalgunner is offline
post #157 of 158 Old 04-15-2019, 09:48 PM
Quoted: 12 Post(s)
Liked: 3
Make sure to also get these if using a Logitech Hub with 2.5mm plugs and LINESO adapters.
Monoprice 2.5mm TS Mono Plug to 3.5mm TS Mono Jack Adapter, Gold Plated https://www.amazon.com/dp/B005KP2AJY..._xWvTCbWRPKDW8
CESS 3.5mm Male to 2.5mm Female Mono Audio Headphone Jack Adapter - 3.5mm Mono Male to 2.5mm Female (2 Pack) https://www.amazon.com/dp/B017CBSAFQ..._Y2vTCbTFWN0EN
post #158 of 158 Old 04-19-2019, 03:08 PM
azz7686's Avatar
Quoted: 278 Post(s)
Liked: 125
My extension is 50' had to double up the pairs on the cat5 to make it work/carry the current.
Spoiler!
azz7686 is offline
Reply Remote Control Area
