Harmony Elite - Page 128 - AVS Forum | Home Theater Discussions And Reviews
 1070Likes
post #3811 of 3849 Old 06-12-2019, 08:05 AM
Quoted: 20 Post(s)
Originally Posted by Rgrim74 View Post
I've owned the Harmony 950 for about a month now, could someone please tell me where/how to use the HELP feature on this remote. All the old Harmony remotes I've owned had the hard button but I can't seem to find it anywhere on the 950. Sure would keep me from answering phone calls all day from my kids trying to figure out what they did wrong by not pointing the remote towards the front of the room. Thanks in advance.
Well, finally picked up the Harmony Hub. The hub itself is in my media cabinet and had to run the IR Blaster over to the center channel speaker which is directly under the Samsung 75" TV. I mounted the IR Blaster to the back of the center channel because for what ever reason the TV was the only thing the Hub itself would not power on. Everything including the electric screen as well as the projector powered on with just the Hub but for whatever reason not the television. All-in-all, everything works flawlessly now and I no longer get the dreaded phone calls as to why something isn't working.
Rgrim74 is offline
post #3812 of 3849 Old 06-13-2019, 01:58 PM
noah katz's Avatar
Quoted: 1759 Post(s)
Liked: 617
It's not clear from the options presented that there's a way to have the Harmony not mess with a device's power settings; see pic.
I don't want to waste lamp strikes on my projector trying to figure this out.
Is there any I can't just leave the projector device out of an activity?
I'm fine with switching to it to power on/off and make any adjustments necessary, plus I can add any of its remote buttons that I use a lot (like lens memories) to the activity, right?
Noah
noah katz is offline
post #3813 of 3849 Old 06-13-2019, 02:09 PM
David Ortiz's Avatar
Quoted: 34 Post(s)
Liked: 32
I have a projector and a TV in my living room. I have an activity I call "Use Projector" which is the only activity that includes the projector device. I use the power setting that you show selected in your attachment. I choose this activity first. When it's done I choose the correct activity for the source I want to use.
My other activities are set up as custom activities, which don't require a display device, so these activities don't try to turn a display on/off as long as you don't add a display when you set up the activity.
noah katz, spyboy and tanman like this.
David Ortiz is offline
post #3814 of 3849 Old 06-13-2019, 02:24 PM
noah katz's Avatar
Liked: 617
Got it, thanks
Noah
post #3815 of 3849 Old 06-13-2019, 02:37 PM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
If you don’t use the projector in a specific activity just don’t include it in that activity. I’m honestly not sure what problem you are trying to solve...
ipca204 likes this.
Mark
mjwagner is offline
post #3816 of 3849 Old 06-13-2019, 02:38 PM
noah katz's Avatar
Liked: 617
@thrillcat
What email address?
I've tried multiple support avenues and the best I can get is a tiny box to type into, or a phone #.
Originally Posted by thrillcat View Post
Well, I contacted Logitech via email. They responded, asked what specific activity I was having the problem with, I told them, and when I got home from work I synced, and it worked.
Kinda creepy, but also, it worked.
Noah
post #3817 of 3849 Old 06-13-2019, 02:43 PM
noah katz's Avatar
Liked: 617
Originally Posted by mjwagner View Post
If you don’t use the projector in a specific activity just don’t include it in that activity. I’m honestly not sure what problem you are trying to do,ve..,
I don't want the projector turning on or off unless I personally tell it to.
Maybe once I understand things better I'll do it the Harmonious way, but I'm still struggling to set things up.
I successfully paired my Fire TV and Lutron lights in the beginning, but after pairing the hub and 950 have not been able to do so after many attempts.
The TV as updated its s/w at least once since then so that may have something to do with it.
Noah
post #3818 of 3849 Old 06-13-2019, 05:27 PM
thrillcat's Avatar
Quoted: 508 Post(s)
Liked: 474
@thrillcat
What email address?
Actually I think I did start it with one of the forms on the website. The original email I can find is from Logitech.
I love my iPhone, but it will never replace my turntable. I've never seen Titanic OR XXXXXXXXX. Alexa is a stripper name.
The Cinema 1858 Remodel Thread
thrillcat is offline
post #3819 of 3849 Old 06-14-2019, 05:04 AM
Quoted: 153 Post(s)
Liked: 67
The TV updating it's software will not change anything (unless of course a software update made it change it's IR codes, which of course I have NEVER EVER heard of happening)
I think some of us here (myself included) are confused about what you are trying to do.
ipca204 is offline
post #3820 of 3849 Old 06-14-2019, 05:07 AM
Quoted: 153 Post(s)
Liked: 67
you know, another option is to have the 950 use it's own IR to turn on the tv and that would eliminate the blaster run. You would need "line of sight" from the remote to the tv, though..
ipca204 is offline
post #3821 of 3849 Old 06-14-2019, 05:19 AM
BPlayer's Avatar
Quoted: 413 Post(s)
Liked: 167
The options do just what they say:
"I want to turn this device off when not in use"
If you have an activity that uses this device it will be turned on when the activity is started. If you switch to another activity that includes this device then the device will remain on (no additional power on command sent). If you switch to another activity that does not include this device then a power off command will be sent to it. When the Off button is pressed a power off command will be sent to the device (if it was on in the last activity in use).
"I want to leave this device powered on all the time"
Power an and power off commands are not sent to the device by any activity. This option is typically used for cable boxes that do not have discrete power commands and you leave them in the power on state all the time.
"I want to keep this device on when switching Activities and only turn it off when I press the Off button"
This is very similar to the first option. A power on command will be sent to the device the very first time that an activity that uses this device is selected. After that you can switch to any activity (that use or do not use the device) without any power commands being sent to the device. A power off command will only be sent when the Off button is pressed. This is what some people refer to as "piggy back activities".
You can get support by following the the prompts on this page that will either give you online guidance, initiate an email, or provide phone numbers.
https://support.myharmony.com/en-ca/contact-us
noah katz likes this.
BPlayer is offline
post #3822 of 3849 Old 06-14-2019, 05:27 AM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
Why do you want to have to manually turn the projector on and off? The Elite keeps track of what is on and what is off and only turns devices on/off when needed. Here is an example. I use one of my Elites's in my home theater. In my theater I use an AVR, a projector, a BR player, and several streaming devices (their is more involved, like lighting and Sonos equipment but I'm simplifying). Assuming that everything is off, If I press one of my activities, for example Watch Shield, the Elite turns on my projector and sets it to the correct input, turns on my AVR and set it to the right input, and turns on the Shield. Then if I want to watch a BR movie I click on the Watch Movie activity - my projector is already on and on the correct input so no commands are sent to the projector, my AVR is already on so all that is sent is a command to switch to the correct input, my Shield is put to sleep and my BR player is turned on. When I'm done I press the Power Off button in the upper left of the remote and it turns off whatever is currently on since it keeps track.
So now describe exactly what equipment you have and how you want it all to work and we can see if we can help you.
Mark
mjwagner is offline
post #3823 of 3849 Old 06-14-2019, 09:42 AM
noah katz's Avatar
Liked: 617
Can be summed up as two things:
1) Get the Harmony to control my TV; currently it will not (leaving aside that it tells me the lights aren't paired, yet does control them)
2) Keep the Harmony from controlling power to my projector
Noah
post #3824 of 3849 Old 06-14-2019, 09:47 AM
noah katz's Avatar
Liked: 617
Thanks, that's instructive.
Though when I read #2 , it sounds like it would turn something on no matter what; I have the unfortunate talent of always taking the wrong meaning when there's any ambiguity.
Noah
post #3825 of 3849 Old 06-14-2019, 09:51 AM
Quoted: 34 Post(s)
Liked: 32
If you set your TV up using IP control via the hub, it's possible a firmware upgrade for the TV reset a "remote start" function or the like.
post #3826 of 3849 Old 06-14-2019, 09:56 AM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
1 - For TV's usually (their are exceptions) the Harmony controls TV's using IR. So either the hub (which blasts out IR in all directions) or a blaster (which also blasts out IR) needs to be positioned correctly and have line of site to the TV. You can also send IR signals from the handheld remote itself but that is not ideal because then you have to keep the handheld pointed at the TV while it is sending out TV commands.
2 - This is simple. Either don't add your projector to the devices or, if you want to be able to at least send commands to your projector when you want, add the projector to the devices but just don't include the projector in any activities. Their are other ways to set it up too but again, in order to help we need more details about your equipment and how you want to use that equipment.
Mark
mjwagner is offline
post #3827 of 3849 Old 06-14-2019, 10:01 AM
noah katz's Avatar
Liked: 617
Why do you want to have to manually turn the projector on and off?...
It's not that I want to, it's just that I don't mind, and it avoids the risk of unwanted power cycles if things get out of sync, plus some JVC owners have had issues powering down because of the necessary double command.
The below is also helpful, and I think I've got a sufficient grasp now, if I could get the TV to work.
Noah
post #3828 of 3849 Old 06-14-2019, 10:04 AM
noah katz's Avatar
Liked: 617
...2 - This is simple. Either don't add your projector to the devices or, if you want to be able to at least send commands to your projector when you want, add the projector to the devices but just don't include the projector in any activities. Their are other ways to set it up too but again, in order to help we need more details about your equipment and how you want to use that equipment.
I thought that's what I said I would do, but it's been apparent for some time now (not just this thread, I mean years) that my communication skills are lacking.
Noah
post #3829 of 3849 Old 06-14-2019, 10:04 AM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
The double command is simply not a problem. My Optomo projector requires the same. It is very easy to use the MyHarmony application and adjust the shutdown commands to issue the correct two power off commands with a bit of delay between them. Once setup correctly I have never had an issue.
tanman and ipca204 like this.
Mark
mjwagner is offline
post #3830 of 3849 Old 06-14-2019, 10:09 AM
tanman's Avatar
Quoted: 379 Post(s)
Liked: 273
^^ Yes once it is setup correctly it is done deal. Getting to that point takes a few tries!
tanman is offline
post #3831 of 3849 Old 06-14-2019, 10:18 AM
noah katz's Avatar
Liked: 617
I've added it several times using both the hub and from my PC, but I just tried again from the latter; no go.
[edit] Even though it worked fine before with the blaster on top of one of my components in the built-in shelves, I unfurled the wire and put the blaster on a chair right in front of the TV; still no dice.
Noah
post #3832 of 3849 Old 06-14-2019, 10:58 AM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
Do you have the correct IR emitter(s) assigned to control the TV? On the handheld remote click on the gear icon in the upper left of the screen, then Settings, Devices, Hub Assignments then select the device. I recommend setting it to all for trouble shooting which will ensure that the IR signal is being sent out from both blasters, the hub itself, and the handheld.
Mark
mjwagner is offline
post #3833 of 3849 Old 06-14-2019, 11:05 AM
noah katz's Avatar
Liked: 617
Just got off the phone with Harmony; the problem was a screwup with my TV's model number.
Harmony thought it was a Roku TV (which previous models were); he added the correct device and now it works.
And I was mistaken in saying that it worked in the beginning; the s/w told me the TV and hub were paired, but I never controlled the TV (or anything) with the remote because it wasn't paired with the hub.
mjwagner and thrillcat like this.
Noah
post #3834 of 3849 Old 06-14-2019, 11:15 AM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
Glad you got it sorted. Your time was not wasted. You learned a ton about how the Harmony works and how to get it programmed which is all useful knowledge and will help you get the most out of it....
noah katz and NCGoldwinger like this.
Mark
mjwagner is offline
post #3835 of 3849 Old 06-14-2019, 11:16 AM
noah katz's Avatar
Liked: 617
After adding the new TV device and syncing, the tech told me I needed to log out of Myhyarmony and log back in to see the changes with new device.
During my previous shenanigans I remember my session timing out and things were different when I logged back in, so when is that necessary versus just syncing?
Noah
post #3836 of 3849 Old 06-14-2019, 11:22 AM
noah katz's Avatar
Liked: 617
Very true, while things were stalled on the functional front, everyone's helpful posts were percolating, and I believe I have a pretty good handle on things now.
We'll see if that's really true when I continue with setup, though not sure I'll have time to try before heading out of town for the weekend.
Noah
post #3837 of 3849 Old 06-14-2019, 02:33 PM
KOTULCN's Avatar
Quoted: 240 Post(s)
Liked: 43
One of the downsides to using IR for remote is that you lose the ability to control with app on your phone/tablet.
KOTULCN is online now
post #3838 of 3849 Old 06-14-2019, 05:45 PM
Quoted: 1549 Post(s)
Liked: 863
Since the phone or tablet is communicating with the hub wouldn’t the hub still send the commands needed be it IR, Bluetooth or whatever?
mjwagner likes this.
Mike
Sony XBR-65X930E | ATV4K-64GB & 32GB 5th Gen | Nvidia Shield TV Pro 2017 | Logitech Harmony Elite
m_snow is online now
post #3839 of 3849 Old 06-14-2019, 08:15 PM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
Not with the hub based Harmony remotes.
Mark
mjwagner is offline
post #3840 of 3849 Old 06-14-2019, 08:18 PM
mjwagner's Avatar
Quoted: 779 Post(s)
Liked: 593
I haven’t logged out of the MyHarmony application in a long time. Have made many changes, never an issue.
Mark
mjwagner is offline
Reply Remote Control Area
