Harmony Elite - Page 180 - AVS Forum | Home Theater Discussions And Reviews
 1655Likes
post #5371 of 5390 Old 05-22-2020, 04:16 PM
dsskid's Avatar
Quoted: 308 Post(s)
Liked: 286
Anyone have any luck in pairing the Elite with the new TiVo Stream 4K?
ISF Calibrator
Samsung PN64F8500, Denon AVR-S910.
Pioneer Kuro Elite Pro-111FD, Denon AVR-X2400H, Palliser Flicks lOlOOlOl Dax material.
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #5372 of 5390 Old 05-22-2020, 06:33 PM
mdavej's Avatar
Quoted: 3281 Post(s)
Liked: 1502
I've seen several reports that Nvidia Shield device also works for the Stream.
mdavej is online now
post #5373 of 5390 Old 05-22-2020, 06:35 PM
Quoted: 418 Post(s)
Liked: 209
Does that mean it pairs via bluetooth? I personally see no reason for the stream to exist, but i guess it will be helpful to some people consolidating there viewing options. I mean, tivo gives us their first streaming stick and it DOESN'T work with your tivo devices? sheesh..
ipca204 is online now
post #5374 of 5390 Old 05-22-2020, 06:42 PM
mdavej's Avatar
Liked: 1502
Yes, it pairs via BT.
https://www.tivocommunity.com/commun...the-4k.577471/
I'm also quite disappointed by the lack of Tivo DVR integration. As it stands right now, it's just another subpar Android TV dongle.
Keenan likes this.
post #5375 of 5390 Old 05-22-2020, 07:42 PM
Quoted: 418 Post(s)
Liked: 209
most of the joe six pack people over on the ridiculously overhyped (and obviously paid for) slick deals thread think this thing is the greatest device since sliced bread! i just shake my head...
and apparently they are charging some people $13+ dollars to return it if they don't like it! THAT will go over well..
post #5376 of 5390 Old 05-23-2020, 04:20 AM
dsskid's Avatar
Quoted: 308 Post(s)
Liked: 286
Not to deviate from this thread,.... Aside from the cost to return, it’s not a bad streamer for $50 (for now, not worth $70). Kind of like a lower powered Nvidia Shield TV. I have the Shield, Fire TV, and Roku, and the format better than the Fire TV and Roku. But to each his own.
Here’s hoping that Harmony does an update and includes it.
Ps, thanks for the temporary Shield workaround for the TIVO, but I’ll wait for full functionality.
ISF Calibrator
dsskid is offline
post #5377 of 5390 Old 05-26-2020, 02:15 PM
mikela's Avatar
Quoted: 499 Post(s)
Liked: 721
Smart Plugs
Hi Folks,
I just ordered a Harmony Elite + Hub and have started working my way through this thread. I have a 3 D-sonic mono block and 2 D-sonic multi-channel amps. Is there a recommended smart plug to use for sequenced power up?
Mike
mikela is offline
post #5378 of 5390 Old 05-26-2020, 07:10 PM
rdgrimes's Avatar
Quoted: 4061 Post(s)
Liked: 3381
Originally Posted by mikela View Post
Hi Folks,
Mike
I prefer a less complicated approach using a power strip with "master-slave" function. Plug the AVR/Pre-pro into the master plug and amps into the slave plugs. Just make sure the power strip is rated for enough amps. THESE TrippLite units work pretty well.
mikela likes this.
rdgrimes is online now
post #5379 of 5390 Old 05-26-2020, 09:15 PM
mikela's Avatar
Quoted: 499 Post(s)
Liked: 721
Thanks for the response, however, I don't think that will work for my situation. My theater has a 60A main panel with 8 circuits. I neglected to mention that I have 3 Behringer EP4000 amps on separate 20A circuits powering 12 15" Ficar subwoofers in a single bass array configuration in addition to amps for LCR and surrounds. Even though I am pretty sure I could power up amps simultaneously, I would prefer a slight delay in between during power up. From what I have read so far, it looks like I will need another hub (home automation?) for the smart plugs. Even then, I'm not sure if it can be properly sequenced with my other equipment.
mikela is offline
post #5380 of 5390 Old Yesterday, 08:48 AM
bmcn's Avatar
Quoted: 2524 Post(s)
Liked: 3430
afaik, smart plugs controlled by Hub/Elite require a Harmony Extender, a discontinued product, and devices powered by smart plugs do not appear to have delay or sequencing options that are available to devices directly controlled by Hub/Elite.
mikela likes this.
bmcn is offline
post #5381 of 5390 Old Yesterday, 09:21 AM
Quoted: 47 Post(s)
[QUOTE=bmcn;59714640]
You would have to setup a hub like SmartThings, run WebCore on it and setup timer delays to turn the smart plugs on if you wanted it to be run automatically. You can also use SmartTiles by ActionTiles in conjunction with SmartThings and have a virtual desktop to turn them on or just use the apps with your phone to turn them on.
Simpler to setup a piston on WebCore to activate when Harmony sends commands to turn your receiver on.
mikela likes this.
jdbarnes63 is offline
post #5382 of 5390 Old Yesterday, 11:05 AM
mikela's Avatar
Quoted: 499 Post(s)
Liked: 721
Thumbs up
[quote=jdbarnes63;59714790]
Thanks!!! Much appreciated. I had already begun looking at SmartThings as an option but this confirms it. Just received my Elite and am super excited about getting this set up. Will take a closer look at WebCore.
mikela is offline
post #5383 of 5390 Old Yesterday, 11:49 AM
Shrike645's Avatar
Quoted: 113 Post(s)
Liked: 79
[quote=mikela;59715390]
I'd take Hubitat over SmartThings. Can be done with the Rule Machine and all processing is local and not dependent on the cloud.
mikela likes this.
Shrike645 is online now
post #5384 of 5390 Old Yesterday, 11:58 AM
noah katz's Avatar
Quoted: 2525 Post(s)
Liked: 946
Not sure what your concern is, but it takes quite some time at a significant overload to trip a breaker.
Noah
noah katz is offline
post #5385 of 5390 Old Yesterday, 12:23 PM
Quoted: 47 Post(s)
[quote=Shrike645;59715616]
I agree on the Hubitat, trick is finding one at this time. The Wink debacle has pretty much devastated the supply of Hubitat's. I contacted them to be put on a notification list as soon as they can get more built. WebCore will work with them as well. Hubitat working locally will minimize latency and if your internet drops, remove the loss of local control (speak from experience, home automation sucks when dependent on the internet).
mikela likes this.
post #5386 of 5390 Old Yesterday, 12:28 PM
Quoted: 47 Post(s)
As Shrike645 stated, the Hubitat is a better local system, but until they become available again, SmartThings will get you in the game of home automation. Let you setup what you want now, and on a positive note you can migrate from SmartThings to Hubitat fairly easy and if you have things that will only work over the internet still control and see them if you keep both hubs active.
mikela likes this.
post #5387 of 5390 Old Yesterday, 02:21 PM
mikela's Avatar
Quoted: 499 Post(s)
Liked: 721
Not a concern but a preference.
mikela is offline
post #5388 of 5390 Old Yesterday, 02:37 PM
mikela's Avatar
Quoted: 499 Post(s)
Liked: 721
One thing I can say is that this system is really easy to set up. Now I need to run an extension to get one of the IR emitters down into the theater to turn on the projector. Thanks for all the assistance. I now feel there is a possibility my wife may be able to operate the theater
mikela is offline
post #5389 of 5390 Old Yesterday, 05:05 PM
Shrike645's Avatar
Quoted: 113 Post(s)
Liked: 79
[quote=jdbarnes63;59715824]
I think they said in the forum that they expect to have a supply in about 2 weeks. Worth the wait.
edit from their forum
More hubs are on order, delayed somewhat due to international supply chain disruptions that affect many different elements of manufacturing and distribution. In a few weeks we expect to be able to accept orders again. If you wish to be notified of availability, please send a note to [email protected].
mikela likes this.
post #5390 of 5390 Old Yesterday, 11:41 PM
mikela's Avatar
Quoted: 499 Post(s)
Liked: 721
[quote=Shrike645;59717436]
I'm in no rush, so I'll hold out for one of these. Thanks for the info! Time to shop for smart plugs.
mikela is offline
Reply Remote Control Area
