Nevo C2 stuck in Upgrade Mode - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-09-2015, 01:24 PM - Thread Starter
htpcforever's Avatar
Quoted: 493 Post(s)
Liked: 193
I followed the procedures listed here:
http://www.hifi-remote.com/forums/vi...?p=27215#27215
10) For the Xsight Color and Xsight Touch:
- Home, Settings, Reset. Press Reset again or enter 981 then Reset for a full reset
- If the remote is unresponsive, it may be stuck in firmware upgrade mode. To recover from that on the Xsight Color, press the Power, 1 and 3 buttons while putting the battery back in. On the Xsight Touch, press Power and OK while putting the battery back in. Then re-connected to PC and continue with the firmware upgrade
But neither of the two methods work.
When I try to connect via the EXRC website to do the update, I get a Call Failed error. I initially had the USB Drop Out issue, so I added the reg key (it is in a different location than what the .reg file shows, but not too much off), but in the meantime the website had placed it in Upgrade Mode and now I am stuck...
htpcforever is offline
post #2 of 6 Old 11-18-2015, 10:07 PM
ianeicher's Avatar
Did you ever get this to work? I just got a C2 and the same thing happened to me (windows 10).
ianeicher is offline
post #3 of 6 Old 11-19-2015, 06:41 AM
mdavej's Avatar
Quoted: 3306 Post(s)
Liked: 1530
In Windows 8/8.1/10, you have to do the reg fix twice when you first connect a new remote running an older firmware. The first firmware upgrade phase in EZ-RC changes the remote name, creating a new registry entry. Because of that, the remote will no longer stay connected, hence gets stuck in upgrade mode. To fix this, go to that new registry entry and do the fix again. Disconnect/reconnect, then go back to ez-rc and click through to connect and upgrade again. This time the upgrade should finish and the remote goes back to normal.
Here's the registry fix:
Go to the key, [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\U SB\VID_06E7&PID_80xx\XSIGHT.\Device Parameters] and change EnhancedPowerManagementEnabled to 0. Change takes effect next time remote is plugged in.
Different Xsight models have different PID's (xx is different). So this key should get you close no matter what model since the VID is the same for all Xsight and Nevo models.
When you first plug in a remote with an older firmware, the key is "XSIGHT.". After the first upgrade attempt, a new key "Xsight" is created. You must make the above change to the new key and retry the upgrade (disconnect/reconnect, click Connect in EZ-RC and click Upgrade again).
Additionally, in Win 10, the Edge browser is not compatible with the EZ-RC website (account creation and connection will fail). So right click and open in IE mode. Other browsers (Chrome, Firefox, Safari, etc.) wont' work either.
mdavej is online now
post #4 of 6 Old 11-19-2015, 08:33 AM
ianeicher's Avatar
Thanks. The link in your signature actual does a good job explaining with the exception of the 2nd loop of changing reg keys. That should probably be updated. Anyway, I'm still stuck in upgrade loop. I've tried the reset tricks and neither work. Any other ideas?
post #5 of 6 Old 11-20-2015, 07:50 AM
ianeicher's Avatar
Ok, per @mdavej 's suggestion, I tried plugging in to a Windows 7 computer and the the EZRC software was able to get the remote off of upgrade mode. I seem to be back in business now. I guess the moral is to stay away from Win8/10 wit this remote.
post #6 of 6 Old 11-20-2015, 07:58 AM
mdavej's Avatar
Liked: 1530
Glad you got it going.
Firmware upgrade in Win 10 is indeed fraught with danger and does not ever go smoothly. So doing that part in Win 7 if you can is definitely the safest approach. But once you get past the upgrade, Win 8/10 should work fine if all the registry changes are correct.
Xsight support says you can't use Win 8/10 at all, so we're lucky to have any workaround at all.
Reply Remote Control Area
