Program old JP1 remotes for ATSC subchannels? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-08-2016, 11:41 PM - Thread Starter
bizzybody's Avatar
Quoted: 16 Post(s)
Question Program old JP1 remotes for ATSC subchannels?
I have a Cable One S014801 and a Cable One 1055WC0-XXX-0001-001 / C055105. Can these be programmed with a JP1 cable to repurpose one of the buttons as the . or - for direct tuning of ATSC subchannels?
I don't have Cable One, picked these up at a thrift shop because they have the programming connector.
I also have a Radio Shack remote I made a parallel port programming cable for, the simple one that only uses a couple of resistors. Far as I can find, these other remotes won't work with that cable.
bizzybody is offline
post #2 of 3 Old 02-09-2016, 05:21 AM
mdavej's Avatar
Quoted: 3074 Post(s)
Liked: 1394
Yes, but you usually don't need a cable for just one function. You can program those manually, assuming you can find a setup code that already gives you partial control.
You are correct that your old parallel cable won't work.
What make/model of device do you need the dash for? Have you found a setup code that works for the other functions at least, and if so, what is it?
mdavej is offline
post #3 of 3 Old 02-10-2016, 07:00 AM
RandyWalters's Avatar
Quoted: 676 Post(s)
Liked: 898
You may not need the . or - button depending how your particular TV's ATSC tuner works.
On my Sony W800B for instance, i have the analog broadcast channels (2, 5, 11, etc) deactivated in the channel list so to get to channel 2.1 i press the 2 button then press Ch Up once and it then tunes to 2.1 (using various older remotes that don't have a . or - button). And once i'm on a digital channel, i press Ch UP or Ch DOWN to go to the other digital channels (it skips the analog channels since they're deactivated in the menu).
Might be a workaround until you get the remote set up . . . .
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Darbee DVP-5000S, Onkyo TX-SR333 AVR, URC MX-890 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Reply Remote Control Area
