Still no discrete code to directly select TV/Ant on Panasonic plasmas? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-01-2016, 09:59 AM - Thread Starter
Atalla's Avatar
Quoted: 22 Post(s)
Question Still no discrete code to directly select TV/Ant on Panasonic plasmas?
Sorry to post a new thread, but hard to navigate the 500 threads started a decade ago on this topic. :-)
Are we still relegated to a 2-step Input+1 or using channel up/down to get to an OTA channel from a Harmony remote?
Atalla is offline
post #2 of 7 Old 03-01-2016, 10:19 AM
mdavej's Avatar
Quoted: 2992 Post(s)
Liked: 1341
I don't think anything has changed. "Input TV" discrete code is still Panasonic protocol, device 128.2 , OBC 48.
mdavej is offline
post #3 of 7 Old 03-03-2016, 08:29 PM - Thread Starter
Atalla's Avatar
Quoted: 22 Post(s)
Logitech support added this command to my remote and same behavior...meaning nothing happens when this command is executed. Working with them to see if there is any other option here.
Atalla is offline
post #4 of 7 Old 03-04-2016, 05:52 AM
mdavej's Avatar
Liked: 1341
Shoot. That's the only code I've got. Was hoping it would do the trick.
mdavej is offline
post #5 of 7 Old 03-06-2016, 08:54 AM - Thread Starter
Atalla's Avatar
Quoted: 22 Post(s)
In the meantime, I taught the Harmony the Input selection menu from another remote and have the two-step macro in place. It works reliably and only lacks elegance since the Input menu flashes on the screen. I expect it'll do.
Atalla is offline
post #6 of 7 Old 03-06-2016, 09:29 AM
RandyWalters's Avatar
Quoted: 669 Post(s)
Liked: 887
On my Panasonic Plasma installs, to switch directly to the TV Tuner i create a 3-step Macro ( 2 dot 1 ) which forces the TV to tune to OTA channel 2.1
I like this method better than bringing up an Input menu and scrolling, or using Ch Up/Ch Down as it will end up going to the next higher or lower channel than what it was on previously. Going directly to ch 2.1 is clean and quick, and is a consistent reliable anchor for entering TV Tuner mode.
It also works on Sony LCD TVs.
If you have to do it using the Input Menu, you could add the Exit command to quickly clear the menu from the screen.
____________
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Darbee DVP-5000S, Onkyo TX-SR333 AVR, URC MX-890 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 7 Old 03-08-2016, 11:21 AM - Thread Starter
Atalla's Avatar
Quoted: 22 Post(s)
Thanks @RandyWalters . The go-to channel idea is a good one. I am using the Input+1 macro right now and the Input menu exists immediately upon input selection, so it is pretty fast. I actually think I can shorten the button delays for the set and do even better. The defaults are overly generous. I might compare the two options and see which one is quicker.
As a general follow-up, after going back and forth with Logitech support, they officially changed the InputTV command in the profile for my specific model to the two-step Input+1. They couldn't come up with an alternative.
Atalla is offline
Reply Remote Control Area
