Oneforall Remote URC7140 Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-01-2016, 05:23 AM - Thread Starter
Liked: 0
Hi guys,
I purchased a URC7140 OneForAll remote yesterday to control my Toshiba TV, my Virgin Media Tivo Box and hopefully, my WDLIVE Media Player. I have easily setup my TV and Tivo box by using the TV and SAT modes. Now, I've come to configure my WDLIVE Media player box and managed to find that the prefixed code 2558 should work. However, because I am using a Tivo box on my SAT connection (and the WDLIVE wants to use the SAT mode also) the code doesn't work on anything but the SAT mode - doesn't work on the DVD or AMP modes.
I have tried to get the remote control to "learn" all of the buttons from the WDLIVE remote control but this doesn't work very well - it will remember about 2-3 key presses and then start failing.
Is there anything I can do? Can I replicate the SAT mode on other modes like DVD or AMP?
Mark
markdagger is offline
post #2 of 3 Old 08-01-2016, 05:54 AM
Edmund's Avatar
Quoted: 74 Post(s)
Liked: 38
Try changing Dvd device to a SAT device:
1. Press SAT
2. press and hold SET or SETUP whatever's its called on this remote, for two blinks, release
3. 9 9 2
4. press dvd device key
Now retry the sat code on the dvd device.
Edmund is offline
post #3 of 3 Old 08-01-2016, 05:57 AM - Thread Starter
Liked: 0
Edmund,
Thanks for this! So, should this basically allow the DVD mode to accept codes normally for the SAT mode?
Thanks again - will try this evening.
Mark
Reply Remote Control Area
