FINALLY SHIPPING - PDP PlayStation 4 IR Receiver For Logitech Harmony - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 113 Old 01-10-2018, 03:34 PM
Murilo's Avatar
Quoted: 275 Post(s)
Liked: 66
Originally Posted by Legairre View Post
The PDP power off doesn't seem to work.
1) Add the PS4 from the Harmony database to your activity.
2) Add PDP from the Harmony database to your activity.
3) When setting up the activity it will ask "which device plays the movie" select the PDP
4) After you finish creating the activity click on "customize this activity" and go into the activity startup command and add the PDP PS command to start the PS4.
5) Then go into the activity shutdown commands and you'll see the PDP off command and the PS4 off command have both been automatically added and you'll be all set.
The PDP will turn on the PS4 and the PS4 will shut down the PS4.
Here are some screen shots of the settings from above:
THanks I tried that but I must have did something different because if I did not turn the ps off with the harmony (say i turn it off with the controller) the power down was in turn, turning the ps4 back on, which does not make sense because the bluetooth ps4 with the power off command could not turn it on.
I did some testing again last night doing steps like you suggested once again and then it seemed to work. I will just double check one more time at home the power off command cannot turn it on (I really dont see how when its off the bluetooth ps4 device is not connected) but just to make sure.
It looks like that should work though. Now i just need them to somehow incorporate the switch. But logitechs hands are tied on that.
Murilo is offline
post #32 of 113 Old 01-10-2018, 04:07 PM - Thread Starter
Legairre's Avatar
Quoted: 1294 Post(s)
Liked: 748
So you're saying you started the PS4 activity with the Harmony, but used the controller to turn off the PS4 and then just used the Harmony (I'm guessing off button or just turned off your PS4 activity) to turn things off and it turned on the PS4?
You know I've never tried this. I always start my PS4 activity with the Harmony and end the activity with the Harmony. I've never used the controller to turn off the PS4 after I started it with the Harmony.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is offline
post #33 of 113 Old 01-10-2018, 05:02 PM
Murilo's Avatar
Quoted: 275 Post(s)
Liked: 66
Yes that was what happened, but using your method I do not encounter this issue which is great, I must have screwed something up (although I dont know what or how its possible). When I started from scratch doing steps like yours it operates fine.
I also have it open the bluetooth ps4 remote after because i find it more responsive.
Took a bit of tweaking but i am perfectly happy, I can turn it on, turn it off, and everything controls snappy with the bluetooth ps4 device.
Murilo is offline
post #34 of 113 Old 01-14-2018, 04:49 PM
demariners's Avatar
Can I use this device using HEX commands and URC/Crestron?
If so does anyone have the HEX commands. I see someone posted the NEC commands. Would I then just program into my URC or Crestron and put a flasher on the front of this kit and be good to go?
How are people using this without a Harmony Remote? Can you?
demariners is offline
post #35 of 113 Old 01-14-2018, 07:50 PM
mdavej's Avatar
Quoted: 3148 Post(s)
Liked: 1445
Read the post with the codes.
mdavej is online now
post #36 of 113 Old 01-14-2018, 07:52 PM
demariners's Avatar
Yes I see the NEC codes. Have you converted them to HEX?
Also, I was curious if I can use these with any remote or is it specific to Harmony? I am not familiar with Harmony remotes.
That's why I am wondering if this item will work.
post #37 of 113 Old 01-14-2018, 08:06 PM
dalto's Avatar
Quoted: 1291 Post(s)
Liked: 658
You can use ir scrutinizer to convert what mdavej posted above to hex, it is free windows software. It should work with any system that can support adding IR codes manually.
dalto is offline
post #38 of 113 Old 01-14-2018, 08:14 PM
mdavej's Avatar
Liked: 1445
A little shortcut in Scrutinizer would be to start with this file (must log in to download), then export to CCF or whatever URC expects.
http://www.hifi-remote.com/forums/dl...&file_id=25035
Or maybe a big company like URC could get their own codes without relying on the kindness of strangers. So has anybody actually asked them?
post #39 of 113 Old 01-14-2018, 08:24 PM
demariners's Avatar
Have they been tested as HEX yet? Thank you so much for the help. Where did you get the codes?
post #40 of 113 Old 01-14-2018, 08:33 PM
mdavej's Avatar
Liked: 1445
I got them the from a Harmony remote using IR Scrutinizer and an IR Widget. Dalto tested all of them.
post #41 of 113 Old 01-14-2018, 08:38 PM
demariners's Avatar
Cool. Well I ordered the unit and I will test them with Crestron. Thank you!
post #42 of 113 Old 01-14-2018, 09:22 PM
ShoutingMan's Avatar
Quoted: 346 Post(s)
Liked: 81
Interested in if and how this can work with a URC remote. I’ve got an MX-780 and a mostly functional copy of CCP.
ShoutingMan is offline
post #43 of 113 Old 01-14-2018, 10:01 PM
demariners's Avatar
I would assume it would if you can put Hex codes in.
From what I can tell it is Bluetooth to the PS4. But it has a IR receiver on the unit which then sends to the PS4 via bluetooth.
When I get it I will play with it and Crestron. If it works with Crestron it will work with URC.
ShoutingMan likes this.
post #44 of 113 Old 01-14-2018, 10:05 PM
dalto's Avatar
Liked: 658
Yes, the codes will work with the CCP. You can manually add the hex codes.
dalto is offline
post #45 of 113 Old 01-15-2018, 08:35 PM
demariners's Avatar
Ok, I think I was able to convert all the Hex. I will post on this thread.
However I do not see the "Options" Button or the "Return" button from the PDP Remote. Also options is the same on the PS controller I would assume. Not sure where that code is on your list but I do not see it.
post #46 of 113 Old 01-15-2018, 08:57 PM
demariners's Avatar
Here are the Hex Commands I converted. I have not tested them all yet but I will tomorrow once I have the kit up and running with an IR.
If anyone needs the Crestron IR driver please email me at [email protected].
0
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
1
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
2
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
3
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
4
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
5
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
6
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
7
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
8
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
9
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Red Circle
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Green Triangle
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Yellow Square
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Blue Cross
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
PS
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
Popup
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Info
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
Top Menu
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Guide
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Up
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Down
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Left
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Right
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Enter
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
L1
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
L2
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
L3
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
Play
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Pause
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Rewind
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
FastFwd
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Stop
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Eject
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
Exit
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Skip Fwd
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Skip Back
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
R1
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
R2
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
R3
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 05F7 015B 0057 0016 0E6C
Share
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
madhuski likes this.
post #47 of 113 Old 01-16-2018, 11:56 AM
dalto's Avatar
Liked: 658
I don't have mine in front of me right now but options is probably "Yellow Square" and return is probably "Red Circle". I would check that once you get it setup though.
dalto is offline
post #48 of 113 Old 01-16-2018, 04:54 PM
demariners's Avatar
Here's one about 2 sec long. Would be nice if someone with a URC reading this thread could test it first. Otherwise, send it to Logitech and see how it works.
Code:
PS-long
0000 006C 003E 0000
015B 0057 0016 0E6C 015B 0057 0016 0E6C 015B 0057 0016 0E6C 015B 0057 0016 0E6C
I can confirm that this does not work. All other HEX commands function perfectly on URC and Crestron. Just need to know how to do Power Off, Power On, and Options. As I do not have a Harmony remote I can not learn these functions. I do not believe that URC database has this yet either.
post #49 of 113 Old 01-16-2018, 06:04 PM
jbn008's Avatar
Quoted: 278 Post(s)
Liked: 152
Does your PDP automatically connect when you power on the PS4? Every time I turn on the ps4 I'm having to reconnect it under bluetooth devices. Am I missing something?
thanks
ps I use the hibernation/sleep mode and not full off
jbn008 is online now
post #50 of 113 Old 01-16-2018, 06:42 PM
dalto's Avatar
Liked: 658
"PS" is what I am using for power on. Power off will probably need a macro.
dalto is offline
post #51 of 113 Old 01-16-2018, 07:05 PM
demariners's Avatar
Anything for Options?
post #52 of 113 Old 01-16-2018, 07:06 PM
demariners's Avatar
thanks
I?m not experiencing this at all. It always connects. However I have it pressing the PS button each time I turn the system on. Maybe that triggers connection.
post #53 of 113 Old 01-16-2018, 08:33 PM
orangetux's Avatar
PS-long does not work
Code:
PS-long
0000 006C 003E 0000
Thanks for posting, but I can confirm PS-long does not work. It just detects as a PS press and release. In fact, none of the NEC1 120 120 commands work with repeat. Any ideas?
orangetux is offline
post #54 of 113 Old 01-16-2018, 09:34 PM
mdavej's Avatar
Liked: 1445
Can anyone confirm that an actual long press from the PS button on a Harmony works? If so, I'll just provide pronto hex of that rather than my attempt at repeated frames.
I don't know what to tell you about the rest. They appear to generate a normal repeating signal on my hardware (JP1).
post #55 of 113 Old 01-17-2018, 01:26 PM
orangetux's Avatar
Harmony remote repeats correctly
I was able to program a Harmony remote that issued repeat commands properly, including PS-long. Can you try holding down PS with a harmony and recording the raw pulses? I wonder if Logitech has updated this recently. I do not have an IR widget otherwise I would do this myself. Thanks for the help!
post #56 of 113 Old 01-27-2018, 01:05 PM
k1ngf1sh's Avatar
Quoted: 43 Post(s)
Liked: 26
Is anyone else using a Harmony Hub and the Harmony app with the PDP?
I can't get it to turn my PS4 on and off as part of the activity startup/shutdown. I edited the device and told it to turn the PDP off when not in use, and told it that I use two different buttons for power on and off. For power on I told it to use the PS button, and for power off I told it to do PS button for 2 seconds -> down -> down -> cross -> cross.
It accepted all this, but when I create the activity, it can't even turn the PS4 on during the initial setup. I can mash the "on" button for the PDP as much as I want but nothing happens.
If I go ahead and continue with the activity setup, once it's done I can start the activity and go to the PS button and press it, and the PS4 will turn on. I can then hold the PS button and the PS menu comes up just fine.
Not sure what I'm doing wrong...
k1ngf1sh is offline
post #57 of 113 Old 01-27-2018, 10:50 PM - Thread Starter
Legairre's Avatar
Liked: 748
Take a look at post 30 and the pics. https://www.avsforum.com/forum/93-rem...l#post55468004
Legairre is offline
post #58 of 113 Old 01-28-2018, 10:04 AM
k1ngf1sh's Avatar
Quoted: 43 Post(s)
Liked: 26
Hm, ok, that worked. Even though I had configured it to turn the PDP on and off and there was a step for powering on the PDP via the PS button in the activity, manually adding *another* step to press the PS button works to turn the PS4 on.
And even though there was a step in powering off the activity to run the PDP power-off macro, adding the PS4 device into the activity works to turn it off.
Kind of janky. Hopefully Logitech updates things to work a little better.
k1ngf1sh is offline
post #59 of 113 Old 02-10-2018, 07:07 AM
ChiroVette's Avatar
Quoted: 423 Post(s)
Liked: 132
I am on the fence about buying this because it seems like a lot of people are having trouble turning their PS4's off, with regard to post #30 in this thread. Right now, I have stopped using the PS4 activity on my Elite because even using Bravia Sync (I have a Sony TV) to turn the PS4 on, the Activity in Harmony doesn't really work well at all, even if I manually turn on the PS4 or use the Sony Bluetooth PS4 remote to turn it on. I really don't want to bother jumping through hoops to try and use complex hex codes, so these days I am using the XBox One S Activity I created for all Streaming and Blu-Ray/4K content playback, as it works seamlessly with both the Harmony Elite and Alexa.
Is this Sony IR Receiver even worth bothering with at this point?
Note: I can actually have pretty solid control of the PS4 right now with the Elite and even limited Alexa interaction, but in order to do it, I have to manually turn on the PS4 or use Bravia Sync to turn it on. The Activity for PS4 usage on my Elite is completely useless at the moment. But outside the activity, and just controlling the PS4 as a device, works fine. Well except not having receiver control without navigating to the receiver "device" on the remote. Sony really screwed PS4 owners.
ROFLMAO!!! Stupidest forum rule ever!
Dear ChiroVette, You have received an infraction at AVS Forum | Home Theater Discussions And Reviews. Reason: General Warning - Price talk and retail links outside of the deal's area.
ChiroVette is offline
post #60 of 113 Old 02-12-2018, 08:11 AM - Thread Starter
Legairre's Avatar
Liked: 748
The PDP works great. Just set it up like post #30 . The PDP doesn't turn off the PS4 the Harmony does. The PDP turns it on and the Harmony turns it off so just set it up like post 30.
Legairre is offline
Reply Remote Control Area
