Hard Reset URC MSC-400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-12-2019, 04:01 PM - Thread Starter
CNLiberal's Avatar
Quoted: 68 Post(s)
Liked: 65
I picked up a new MX-990 from Surf Remote in California (great folks to work with). I then purchased an MSC-400 off of eBay. I had it all plugged in and was programming the MSC. It was recognized no problem by CCP. I had some errors with my first programming attempt (several OUT OF MEMORY errors) that caused the CCP file to be over 260MB! There weren't even any images or sounds loaded. So I started fresh and wanted to test my cables I made for serial control. I was doing a little more reading and I saw that you had to upload your codes first before you were able to test. I thought I had done that, but I've been working in so many CCP files, that I decided to start fresh. I created a new CCP file, and tried uploading, and the MSC locked up on me. I powered off, and that was most likely a huge mistake. Now, the POWER light comes on, but the STATUS light won't come on, and when I plug a USB into the front, the USB2 light doesn't come on. I'm afraid this thing is bricked. I found the reset button on the bottom, but I can't find the procedure to reset the device. I've tried:
1. While POWER is attached, hitting the button.
2. While POWER is attached, holding reset for 15-30 seconds.
3. With POWER disconnected, holding reset for 15-30 seconds.
No joy on any count. Am I screwed? Does anyone know the proper reset procedure? Thanks.
Fronts: Power Sound Audio MTM-210T | Center: Power Sound Audio MTM-210C | Rears: Power Sound Audio MT-110SR | Sub: JBL PB12
AVR: Denon AVR3312CI
| TV: Sony 65" KDL65W850C | Streaming: nVidia Shield 16GB 2018 | BluRay: PlayStation 3 | HTPC: Kodibuntu
CNLiberal is offline
post #2 of 4 Old 02-13-2019, 06:01 PM
RandyWalters's Avatar
Quoted: 669 Post(s)
Liked: 887
Here are links to the Manual and Tutorial if you don't already have them, maybe there's some useful info in there
http://files.remotecentral.com/view/...ce_manual.html
http://files.remotecentral.com/view/...ial_guide.html
Randy
Sony XBR-55X900E, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Darbee DVP-5000S, Onkyo TX-SR333 AVR, URC MX-890 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - https://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 4 Old 02-13-2019, 06:27 PM - Thread Starter
CNLiberal's Avatar
Quoted: 68 Post(s)
Liked: 65
I've read them and searched them for "reset" and am seeing nothing about how to use it. Guess I was hoping someone remembered some old nugget of info.
post #4 of 4 Old 02-14-2019, 01:21 AM
Edmund's Avatar
Quoted: 74 Post(s)
Liked: 38
There are 2 URC forums on Remote Central, search through both for your answer.
Edmund is offline
Reply Remote Control Area
