Harmony Companion and U-verse Play button - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By mdavej
post #1 of 3 Old 08-11-2019, 11:09 AM - Thread Starter
jimsmith94's Avatar
Quoted: 49 Post(s)
I am a recent U-verse TV customer, and new Harmony Companion Smart Control owner. On my original U-verse IR remote and the A20 RF remote, when something is already playing, the Play button shows the remaining time without pausing the show. This is a very handy feature that I like a lot!
I programmed the Smart Control remote Play button to be Play on the AT&T DVR, but when something is playing, the Play button does show the remaining time, but it pauses the program just like the Pause button does. So far everything else works fine except for this one issue.
Is this a software bug, a limitation of the Play/Pause buttons being on a rocker, or something else? If there is a way to program another button to perform this feature, I can live with that.
jimsmith94 is offline
post #2 of 3 Old 08-11-2019, 12:58 PM
mdavej's Avatar
Quoted: 3290 Post(s)
Liked: 1506
Issue is that Harmony is calling the command on the A20 Pause button PLAY and using that as the sole Play/Pause function. The command on the A20 Play button is apparently missing from Harmony. So you may have to try a few different model choices in the Harmony database until you find a set of commands with distinct play and pause functions. Then you need to assign each to distinct buttons on your Harmony.
Alternatively, there may be another command that accomplishes the same thing, like OK possibly.
jimsmith94 likes this.
mdavej is online now
post #3 of 3 Old 08-11-2019, 01:08 PM - Thread Starter
jimsmith94's Avatar
Quoted: 49 Post(s)
Aha, the OK button does exactly what I want, so I can live with that. Thank you so much!
Reply Remote Control Area
