Xfinity remote won't work over IR extender - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-15-2019, 03:16 PM - Thread Starter
sdavis81's Avatar
Quoted: 22 Post(s)
Hi remote gurus,
I am stumped.
About a year ago I set up a TV on a porch with the equipment in the basement (another location)
Samsung TV
Sewell multizone IR extender, run with long extender cable into basement
Yamaha receiver and Xfinity box down in the basement.
Everything worked fine for 6 months. Then the cable box stopped responding.
The receiver can be controlled over the IR extender fine.
The cable remote controls the TV fine, but won't control the cable box.
If I take the cable remote in the basement, it works fine to control the cable in line of sight.
The Xfinity remotes flash when the signal is sent. The IR 'eye' flashes when it relays a signal. If I push a button on the cable remote that involves a TV function, Like Volume or TV power, the eye flashes (it relays an IR signal). If I push any cable related button like Menu or Xfinity button, the eye does not flash (no IR signal seen or relayed?).
So somehow the signals from the remote that are "TV related" can be seen by the eye and are relayed. But cable functions are not.
I have multiple Xfinity remotes including old ones. I use an XR 15 remote, but had an old XR 5 remote and paired that one. The same thing happens with that one. I have repaired the XR 15 too. None of the cable functions with either will relay over the IR extender.
Using the Xfinity app to watch TV right now.
I have called both Sewell and Xfinity, no one has a clue.
Any thougthts?
My thanks.
sdavis81 is offline
post #2 of 3 Old 09-16-2019, 08:55 PM
Mntneer's Avatar
Quoted: 95 Post(s)
Liked: 58
Originally Posted by sdavis81 View Post
Hi remote gurus,
I am stumped.
Samsung TV
Any thougthts?
My thanks.
It's the Xfinity boxes. Some of them are a complete pain in the arse when it comes to IR emitter placement. Which box is it you're working with?
Mntneer is offline
post #3 of 3 Old 09-17-2019, 06:27 PM - Thread Starter
sdavis81's Avatar
Quoted: 22 Post(s)
The boxes are XiD-P boxes. This same box worked for several months?
sdavis81 is offline
Reply Remote Control Area
