Why isn't my Harmony using discrete codes when available? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-18-2019, 09:22 AM - Thread Starter
swechsler's Avatar
Quoted: 36 Post(s)
I just connected my iPad to my Harmony Smart Control system using the app. By doing that I discovered that my TV has (working) codes for Power On and Power Off (rather than a toggle) that Harmony is aware of, as well as discrete input select; however, the controller is still using the power toggle and cycling through the inputs.
Any idea why this would be, and is there any way to change it?
"When everyone's out to get you, paranoia is just good thinking"
-- Dr. Johnny Fever
swechsler is offline
post #2 of 7 Old 10-18-2019, 09:28 AM
rdgrimes's Avatar
Quoted: 3965 Post(s)
Liked: 3236
If the commands are available in the Harmony database, you only need to change the button commands on your remote's activity setup. Whatever the app is doing may not be related.
rdgrimes is online now
post #3 of 7 Old 10-18-2019, 09:33 AM - Thread Starter
swechsler's Avatar
Quoted: 36 Post(s)
Turning a device on and off is not part of the activity; it's built into the Harmony logic. For example, if I switch from watching TV to watching a BluRay, the remote isn't going to turn the TV off and then on again, it's going to leave it on.
-- Dr. Johnny Fever
post #4 of 7 Old 10-18-2019, 10:02 AM
David Ortiz's Avatar
Quoted: 63 Post(s)
Liked: 58
The MyHarmony app allows you to change device settings. There is a power settings option and an input settings option. In power settings you tell MyHarmony that you "press two different buttons for on and for off" and in input settings you choose "I press different buttons that directly switch to DVD or other inputs."
The mobile app is somewhat different as shown: https://support.myharmony.com/en-us/...anging-methods where the input option is "DIRECT INPUT SWITCHING."
David Ortiz is online now
post #5 of 7 Old 10-18-2019, 10:24 AM
rdgrimes's Avatar
Liked: 3236
There are settings in the MyHarmony software that allow you to change the logic. In the Activity itself you can go to "Customize" and see what command is actually being used for power and input. In the device settings you can go to "Fix a command" and see a list of available commands as a reference.
post #6 of 7 Old 10-18-2019, 10:26 AM - Thread Starter
swechsler's Avatar
Quoted: 36 Post(s)
OK, cool, I'll check it out. Thanks guys.
-- Dr. Johnny Fever
post #7 of 7 Old 10-18-2019, 11:52 AM
Otto Pylot's Avatar
Quoted: 3654 Post(s)
Liked: 2625
I had a similar issue with my 700 not turning On/Off the ATV4k once I updated the ATV4k to iOS 13. Logitech corrected that for me by re-programming the On/Off function to the Home command. However, according to some very knowledgeable ATV4k folks, that's basically just a bandaid and the more correct way is to program the Menu button, or at least add it to the end of the Activity sequence. Input selection was fine for me, it was just the On/Off function that changed. Once the ATV4k was on (via the Apple remote), navigating the various Apple menus with the 700 was fine.
I never trust an atom, they make up everything.
Otto Pylot is online now
Reply Remote Control Area
