Disabling Screen Lock on Harmony Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-16-2019, 07:25 PM - Thread Starter
ttibsen's Avatar
https://www.dropbox.com/s/84sptqhjhr...remot.pdf?dl=0
ttibsen is offline
post #2 of 3 Old 11-22-2019, 02:27 PM
Legairre's Avatar
Quoted: 1298 Post(s)
Liked: 749
Originally Posted by ttibsen View Post
To get into the remotes setting just tap the 3 horizontal lines on top of each other in the lower right corner of the remote's screen.
After making changes you can even re-sync the remote from there. Actually even when you make changes in the harmony software(from your mac) you don't have to hook up a cable to re-sync. Just go into setting and re-sync from there and you'll never need to hook up the cable again.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is offline
post #3 of 3 Old 11-23-2019, 08:54 AM - Thread Starter
ttibsen's Avatar
Thanks - that was the answer I was looking for
ttibsen is offline
Reply Remote Control Area
