Suggestions RF/IR universal remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-21-2019, 02:43 PM - Thread Starter
bg56's Avatar
Question Suggestions RF/IR universal remote
Hoping someone on this forum has solved a similar need. I have a TV located across the room from a streaming device (currently Fire TV) and receiver (TV is connected to streaming device via HDMI cable run through walls/ceiling). Also located with the receiver are a turntable and Sonos Controller. I am looking for a simple universal remote solution and so far, the only suggestion I have is from a local AV guy wanting me to use an MX450/MRF260. I have experience with URC devices (MX850/MRF300) and found them to do a decent job but I'm not comfortable with such old technology. The URC solution works because the MX450 has both RF and IR outputs. The IR output will control the TV and the MRF260 will do IR blaster control of devices co-located with the receiver (except, of course, the Fire TV which is likely to be replaced by a Roku Ultra). Of course, I'm not counting on controlling the Sonos controller with this solution.
As an alternative to URC, I'm thinking of a Harmony Companion and Harmony Hub solution but I don't know how to provide IR control of the TV since it is located across the room from the Harmony Hub location (perhaps there is a "remote" IR blaster that the hub can control)?
Appreciate input from anyone who has solved a similar URC need.
bg56 is offline
post #2 of 5 Old 11-22-2019, 05:48 AM
Quoted: 243 Post(s)
Liked: 120
Harmony Elite will do what you want. Control rack equipment from the Harmony Hub and the tv across the room via IR from the remote.
ipca204 is offline
post #3 of 5 Old 11-22-2019, 09:13 AM - Thread Starter
bg56's Avatar
Thanks - I'll have a look.
bg56 is offline
post #4 of 5 Old 11-22-2019, 09:33 AM - Thread Starter
bg56's Avatar
I've been doing a bit more reading - it looks to me like the combination of Harmony Companion remote with the hub might work as the Hub has an emitter that would most likely be able to control the TV across the family room. If I put the hub on top of the cabinet with line of sight to the TV and if I don't have too much light noise, it seems like it would work.
bg56 is offline
post #5 of 5 Old 11-23-2019, 12:54 PM - Thread Starter
bg56's Avatar
I went with Harmony Elite
As a wrap up for this thread... I went with the Harmony Elite. I think the Companion would have done the job but I like the Elite better. Interestingly, it IS controlling my TV just fine from across the room (both hub and blaster do the job fine) BUT my Denon AVRS540BT is not responding to any commands from either the hub or the blaster. Tried Harmony DB commands and went through teaching process with no luck. I also made the the hub and blaster were positioned the in the same spot as the Denon provided remote which works. Have posted a separate thread on this topic.
bg56 is offline
Reply Remote Control Area
