Harmony Elite - won't control Denon AVRS540BT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-23-2019, 12:50 PM - Thread Starter
bg56's Avatar
Red face Harmony Elite - won't control Denon AVRS540BT
Looking for anyone out there who also has a Harmony Elite and Denon AVRS540BT receiver. The Harmony controls my TV just fine (both from hub and blaster) but the Denon is not responding to any commands. I've tried the Harmony supplied commands and I have gone through the teaching process with no luck. I'm positioning the hub and the ir blaster in the same location I use for the Denon provided remote (which controls the receiver with no problems).
Any thoughts input / comparison of others with the same equipment appreciated.
UPDATE: Not necessarily "SOLVED" but "NO LONGER AN ISSUE". On a hunch, I moved on past the device test and created an activity. The activity is controlling the receiver with no issues. Never figured out why the tests won't control the receiver but not too concerned about it at this point.
bg56 is offline
Reply Remote Control Area
