Blackweb Remote Anybody? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-02-2019, 12:02 PM - Thread Starter
JackB's Avatar
Quoted: 1562 Post(s)
Liked: 376
Does anyone here use a Blackweb remote? I just got one and need some help.
Jack
JackB is online now
post #2 of 5 Old 12-02-2019, 02:04 PM
mdavej's Avatar
Quoted: 3146 Post(s)
Liked: 1441
Looks pretty basic. If whatever you're wanting to do isn't in the manual, then it can't be done. I personally would have bought a JP1 remote instead. Something like the Inteset INT-422 can be programmed to do just about anything using Remote Master. Your remote, on the other hand, is limited to the functions and codes in the manual.
Here's a nice young lady who will walk you through everything the remote can do (which isn't much):
https://www.myblackwebremote.com/
mdavej is offline
post #3 of 5 Old 12-02-2019, 02:34 PM - Thread Starter
JackB's Avatar
Liked: 376
Thanks for the info. In my first programming effort I set it up to sub for my Directv R73 remote. One of the most frequently used buttons is the "Guide" button. There is no Guide button on the Blackweb. No problem. Just program one of the colored buttons. The User Guide says they are programmable. But it doesn't tell you how to program them. If that ability is true then I think the thing might be usable.
Jack
JackB is online now
post #4 of 5 Old 12-02-2019, 02:49 PM
mdavej's Avatar
Liked: 1441
I just looked at the manual and see no mention of the colored buttons being programmable. The only programmable button is FAV, and it only stores a macro consisting of numbers. This remote can't even learn from other remotes.
If I were you, I'd just get another DirecTV remote and return this one. It's really a terrible remote.
mdavej is offline
post #5 of 5 Old 12-02-2019, 04:49 PM - Thread Starter
JackB's Avatar
Liked: 376
I think you are right. I've sent a email to customer support. Let's see what they say.
Jack
JackB is online now
Reply Remote Control Area
