How to program harmony elite to turn on Netflix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-01-2020, 10:45 AM - Thread Starter
genaccmiller's Avatar
Quoted: 789 Post(s)
Liked: 184
Folks - does anyone one know how I can turn Netflix on my Blu-ray player with harmony elite? Currently I have a watch movie activity which automatically turns on the projector, receiver and my Panasonic Blu Ray player. From there I go to Netflix and press the button on the remote. Instead I would like to either have a watch Netflix button on my remote which takes me directly to Netflix or be able to say Alexa turn on Netflix.
Sent from my GM1917 using Tapatalk
Step by Step Theater Build - http://imgur.com/gallery/2tpaSru
My Theater Build Youtube Channel - https://www.youtube.com/channel/UCs_..._as=subscriber
My Theater Build Thread - https://www.avsforum.com/forum/19-de...ld-thread.html
genaccmiller is offline
post #2 of 2 Old 01-01-2020, 10:57 AM
MRAYB's Avatar
Quoted: 329 Post(s)
Liked: 764
@genaccmiller I use a 650 Harmony, should be the same. Using My Harmony software enter the activity wanted. Then "customize this activity". From there you "should" be able to "add a step" telling the Bluray to go to Netflix. Not sure if that will be an option though. I have added a step to mine to eject the bluray tray as a last step in the activity sequence. This is all from the desktop version of My Harmony, not on a phone app. Not all settings are available on the phone app.
If no luck, there is a thread dedicated to just the Elite.
MRAYB is online now
Reply Remote Control Area
