Harmony Ultimate doesn't like LG B9 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-09-2020, 02:49 PM - Thread Starter
47okie's Avatar
I'm not having any luck getting my Harmony Ultimate to control my LG B9 TV. The remote worked flawlessly with my older Samsung, but I've tried editing my Activities by just deleting the Samsung and adding the LG, and I've deleted the Activities entirely and set up new ones, but nothing seems to work. The TV is connected by HDMI to my Yamaha AVR, by a Cat5e to my WiFi router, and by a digital optical cable to the corresponding port on the Yamaha.
Wondering if the power-up order for each device could be a problem.
Any insights would be greatly appreciated.
47okie is offline
post #2 of 5 Old 01-10-2020, 08:35 AM
mdavej's Avatar
Quoted: 3148 Post(s)
Liked: 1445
Make sure the port assignments are correct (remote or hub).
mdavej is online now
post #3 of 5 Old 01-10-2020, 06:39 PM - Thread Starter
47okie's Avatar
By “port assignments “, do you mean the inputs that the AVR and the TV use?
47okie is offline
post #4 of 5 Old 01-12-2020, 01:52 PM
bluewaves's Avatar
Quoted: 29 Post(s)
Liked: 34
Is HDMI ARC, Simplilink, CEC control Turned off???? You also have to remember that the IR sensor for the LG is right at the bottom in the center of the TV so you need to make sure you have a good line of sight to control it
bluewaves is offline
post #5 of 5 Old 01-12-2020, 02:04 PM
mdavej's Avatar
Liked: 1445
No, the port the IR signals come from on Harmony, the remote or the hub or a specific port on the hub.
CEC wouldn't keep it from working entirely. So I don't think that's the problem. I think the problem is no IR is reaching the TV.
Reply Remote Control Area
