Directv multiple boxes in one room - Harmony Elite - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-13-2020, 10:57 AM - Thread Starter
Liked: 0
I'm trying to get my room setup and I have read that it's possible to toggle the Directv boxes IR codes, so that they are unique, but I'm not sure how to do that.
I have 3 Directv boxes and would like the Harmony to independently control each box. Right now, they are clearly all on the same, so each command affects all 3 boxes.
Kyle Quaranta is offline
post #2 of 4 Old 01-13-2020, 05:16 PM
Edmund's Avatar
Quoted: 91 Post(s)
Liked: 59
Model #'s of these directv receivers?
Edmund is offline
post #3 of 4 Old 01-15-2020, 12:57 AM
sbarnesvta's Avatar
Quoted: 27 Post(s)
I haven't done it with Harmony before, but I know there are (8) unique code sets for DTV receivers. In the menu there is a remote setup section that will walk you through how to change the codes in the DTV receiver and the remote so they match. We do this often in commercial applications with multiple DTV receivers in an AV rack.
From the Harmony manual, once the receiver has been added as a device in the harmony app go to Menu> Harmony Setup>Add/Edit Devices> Select your device (DirecTV receiver)> Device Versions > Change IR Language
SBTS-Inc.com
- Certified Crestron Master Programmer and DM T-4K, D-4K, E-4K, DM-NVX Certifications.
- RTI Programmer/ Driver Developer
- Rational Acoustics Smaart Certified
- QSC QSYS Lvl 2 Certified Programmer
sbarnesvta is offline
post #4 of 4 Old 01-15-2020, 06:21 PM
mdavej's Avatar
Quoted: 3163 Post(s)
Liked: 1448
Old receivers had 8, but some new ones have only 1. That's why we need model numbers.
mdavej is online now
Reply Remote Control Area
