AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Remote Control Area (https://www.avsforum.com/forum/93-remote-control-area/)
-   -   Need a very simple remote. (https://www.avsforum.com/forum/93-remote-control-area/3135808-need-very-simple-remote.html)
thyristor44 04-11-2020 11:14 AM
First post so Hello all
I have two music players, one Daphile and the other piCorePlayer. I am using simple remote controls like eBay item number: 142990763594. They are very simple but have enough functions for total control of the music players.
Problem is after about three months they begin to wear out, need heavy push on buttons, then button stops altogether..question is can anyone recommend a similar simple remote that is better quality.
These are 2.4ghz wireless mice but regular IR remote would be fine.
Help appreciated.
thyristor44
RandyWalters 04-13-2020 06:46 AM
That eBay item number doesn't come up . . .
_____________
thyristor44 04-14-2020 11:06 AM
_____________
No I had problems with that number too. They are advertised as universal 2.4g wireless air mouse remote control for pc android tv box. Another one is 232951904373 and that does work for me, ebay uk.
mdavej 04-15-2020 11:41 AM
Similar regular IR remote that is high quality made by world's largest remote maker and should last several years. Also programmable via Remote Master for control of any IR device. Should also be available in the UK.
https://www.oneforall.us/universal-r...remote/support
thyristor44 04-15-2020 01:01 PM
Thanks mdavej
That looks exactly what I need, one slight problem is the systems have no IR receiver input as the cheap ones I use are 2.4ghz wireless.
Squirrel! 04-15-2020 01:04 PM
mdavej 04-15-2020 03:05 PM
Originally Posted by thyristor44 (Post 59498788)
Thanks mdavej
In your initial post you said regular IR would be fine. I don't know the capabilities of the devices you're trying to control.
thyristor44 04-16-2020 03:34 AM
The 2.4g wireless mouse has a usb wireless receiver that plugs in to a usb of the PC or Pi.
IR is fine, but I need an IR receiver that will also plug in to usb on PC or Pi.
Would one of these or similar work as IR receiver. eBay item number:313024863084. Then I could use the Remote you advise.
mdavej 04-16-2020 07:15 AM
No. That's just a USB powered repeater. Must be receiver using MCE, Ortek/Adesso or NEC (Diamond) protocol, not IRDA. Could also be universal like FLIRC.
thyristor44 04-16-2020 10:11 AM
Flirc is too expensive, my systems are very basic.
I have used these: eBay item number: 231528747775. They do last but the layout is very cluttered. Could I use its IR receiver with the Oneforall remote you advised.
mdavej 04-16-2020 10:30 AM
I can't find that item number. But if it's a no-name Chinese one for 6 USD, it won't work. Must mention in the description one of the protocols I listed, like this:
https://www.ebay.co.uk/itm/New-HP-US...a/283384377135
thyristor44 04-16-2020 11:51 AM
Thanks mdavej, that looks the part. Will now find if it works under linux and with raspberry Pi.
mdavej 04-16-2020 01:18 PM
Sounds good. I've gotten Ortek dongles to work with Pi, but never tried MCE ones. They probably work fine, but I can say for sure.
If you end up getting that remote and want to program with Remote Master, you'll need one of these (Original, Independent option):
https://www.ebay.com/itm/Original-6P...o/312234679584
Remote Master does work on Linux and I think Pi as well.
thyristor44 04-18-2020 09:47 AM
I assume Remote Master is to program the remote control from usb of probably PC. Is this about correct.
mdavej 04-18-2020 10:53 AM
http://www.hifi-remote.com/wiki/inde..._Easy_Is_It%3F
Ethan07 04-23-2020 07:45 AM
mdavej 04-23-2020 08:13 AM
Originally Posted by Ethan07 (Post 59537326)
I love the 665 and have a couple myself. It would definitely work great in the OP's situation. But I think the OP would say it has too many buttons. He only wants a few buttons like those found on Roku and Fire TV remotes, hence my recommendation for a bare bones universal remote.
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
