Windows software to control HIFI over rs232? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Vince_B
  • 1 Post By Vince_B
  • 1 Post By smoothtlk
  • 1 Post By Vince_B
  • 1 Post By Peter M
post #1 of 11 Old 05-17-2020, 02:03 PM - Thread Starter
DannyBoy73's Avatar
Quoted: 36 Post(s)
Liked: 31
Hi,
I can a USB -> rs232 cable from my PC to my pre-amp and I can send rs232 over a terminal to control volume etc...
Is there any Windows software out there that will give me a remote control type GUI and I can programme it with rs232 codes that will be sent the local com port?
Basically I'd like to control the volume on my pre-amp from my Windows PC over the USB -> rs232 cable without having to use a terminal and typing in rs232 commands.
Anthem AVM60 | 3 x Tag McLaren 125 Mono Blocs | AudioLab 8000 X7
Monitor Audio: Studio 20s | Studio Centre | GFX Rears | 4 x CT380-IDC ceiling | REL Storm
JVC x7900 with Draper (EuroScreen) ReACT 3.0 (ALR) - 2.35:1 and 3m wide
Lumagen Radiance Pro 4240 | Nvidia Shield (KODI) | PS4 Pro | Switch | Roon
DannyBoy73 is offline
post #2 of 11 Old 05-17-2020, 02:19 PM
Vince_B's Avatar
Quoted: 326 Post(s)
Liked: 227
Not sure if your preamp has network control but if so you can build commands as saved packets in packetsender and then fire them at will or from command line.
DannyBoy73 likes this.
Vince_B is online now
post #3 of 11 Old 05-17-2020, 02:41 PM - Thread Starter
DannyBoy73's Avatar
Quoted: 36 Post(s)
Liked: 31
Thanks Vince.
It's an old Meridian pre-pro (561) and only has rs232. At the mo I'm using PuTTY and just leave it connected to my COM port. I have to type "VN55" to set the volume to 55, works well. So thanks for the packet idea, but that will be pretty similar to what I'm doing with PuTTY.
Was hoping for some software, ideally with a slide bar or something than could send the rs232 commands for me.
post #4 of 11 Old 05-17-2020, 02:44 PM
Vince_B's Avatar
Quoted: 326 Post(s)
Liked: 227
Sure thing. If you’re iOS try Roomie remote. You’ll need their serial network adapter or a global cache serial box. Just checked in Roomie and they do have a meridian g68 that shows up under receivers. Typically the code sets are same or similar within a manufacturer.
post #5 of 11 Old 05-17-2020, 03:03 PM - Thread Starter
DannyBoy73's Avatar
Quoted: 36 Post(s)
Liked: 31
Thanks, will check it out.
post #6 of 11 Old 05-17-2020, 04:06 PM
smoothtlk's Avatar
Quoted: 359 Post(s)
Liked: 115
myServer runs on windows and can control serial port devices. And a whole lot more.
smoothtlk is offline
post #7 of 11 Old 05-17-2020, 05:06 PM - Thread Starter
DannyBoy73's Avatar
Quoted: 36 Post(s)
Liked: 31
Thanks, do you have a link? My google isn't coming up with anything obvious.
Also, on another note... I've managed to get a little pop-up window using Windows PowerShell and am able to assign rsr232 commands to buttons! Needs a little more work, but a bit of fun!
post #8 of 11 Old 05-17-2020, 05:32 PM - Thread Starter
DannyBoy73's Avatar
Quoted: 36 Post(s)
Liked: 31
Here's a quick screen shot of my Powershell app... works a treat! Might try and get feedback from the amp to the app tomorrow!
post #9 of 11 Old 05-17-2020, 08:00 PM
Vince_B's Avatar
Quoted: 326 Post(s)
Liked: 227
That’s pretty cool!
post #10 of 11 Old 05-17-2020, 08:18 PM
Peter M's Avatar
Quoted: 439 Post(s)
Liked: 395
Have a look at EventGhost.
Cheers,
Peter M is offline
post #11 of 11 Old 05-24-2020, 07:56 AM
lagommette's Avatar
Liked: 1
Hi,
You can use my app: HC-SKIPPER.
You'll be able to control your amp via com Port, or RS232 over Ethernet or any Global Caché unit.
Feel free to contact me at [email protected] if you need help.
Best regards,
lagommette
lagommette is offline
Reply Remote Control Area
