Broken Harmony 880 - What should I replace with? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-10-2007, 12:01 PM - Thread Starter
mjbanks's Avatar
So my Harmony 880 has kicked the bucket. It's out of warranty, and the volume up button doesn't work anymore. Since I have to get a new remote, I've been thinking about what I should replace it with.
I need something that has actual buttons instead of a full touch screen (the wife doesn't like full touch screen).
Should I get another Harmony 880, or should I change to another remote? Any suggestions are greatly appreciated.
mjbanks is offline
post #2 of 11 Old 10-10-2007, 12:11 PM
herdfan's Avatar
MX-900. My wife adapted to it very quickly from an 880.
Please do not send me PM's asking for software! You will not get it.
herdfan is offline
post #3 of 11 Old 10-10-2007, 12:38 PM
BillyBeatnik's Avatar
Look at the Harmony 670. It has actual buttons. If you use a DVR or DVD player a lot, the transport controls are all conveniently located in the center around the OK button.
BillyBeatnik is offline
post #4 of 11 Old 10-10-2007, 12:57 PM
bryansj's Avatar
Quoted: 1753 Post(s)
Liked: 789
If you stick with a Harmony remote you won't have to spend much, if any, time reprogramming it. The software allows you to replace the remote and transfers your devices and activites.
bryansj is offline
post #5 of 11 Old 10-10-2007, 02:41 PM
czzer's Avatar
Have you spoken to tech support about it? They might replace it anyway even if it's out of warranty.
czzer is offline
post #6 of 11 Old 10-10-2007, 07:39 PM - Thread Starter
mjbanks's Avatar
Haven't tried calling. It's over 2 years old, so I figured there was no shot of getting it replaced.
I think if I'm sticking with Harmony, I'll just get another 880. I like the features it offers. I don't need the RF stuff of the 890.
mjbanks is offline
post #7 of 11 Old 10-10-2007, 07:51 PM
tokerblue's Avatar
Quoted: 226 Post(s)
Liked: 222
Since you have nothing to lose, you might want to try and see if this will fix your volume button.
https://www.avsforum.com/avs-vb/showt...3#post11864603
tokerblue is offline
post #8 of 11 Old 10-16-2007, 11:34 AM
blitzpb's Avatar
That is very interesting. I have had my harmony for about the same amount of time and MY volume up button has too ceased to play nicely. I have to really mash it to get it to work. I wonder if its a defect. I will be calling logitech today to see whats up! I love the Harmony setup so I cant imagine going with a different brand. Ill let you know what they say.
blitzpb is offline
post #9 of 11 Old 10-17-2007, 03:13 PM
darkwire's Avatar
Darn I wish I saw that fix before I won a 720 on ebay But I'll try the fix anyways, and if it works, I'll sell it on ebay!
darkwire is offline
post #10 of 11 Old 10-22-2007, 08:06 PM
roybishop's Avatar
Amazon has a refurbished 880 for $99.99.
roybishop is offline
post #11 of 11 Old 07-01-2013, 06:18 PM
gwbuss's Avatar
I'm on my second 880 and buttons are now failing on this one also, I won't be buying another one. I will be trying an AR.
gwbuss is offline
Reply Remote Control Area
Harmony 880 Advanced Universal Remote , Logitech Harmony 670 Universal Remote , Logitech Harmony 890 Advanced Universal Remote Control
