URC MX-810 problems - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 31 Old 01-02-2020, 01:39 PM
Liked: 0
MX-810 Disconnected, please try again [EC2]
I know this is an old thread, and the MX-810 is an old remote.
However, I have several of them and like them. Recently, I have had trouble sending software to the remote. I am able to run the software, but when I send software to the remote, it gets about 2/3 of the way done (typically about 82%, but not always the same), and then says
"Disconnected, please try again [EC2]".
At that point I have to remove the battery from the remote, and then try again.
If I keep trying, eventually I can usually get it to complete, but it takes like 10 times or more.
I have tried different USB cables, different USB ports, different remotes, with the battery charger plugged in and not plugged in, etc. but I keep having this problem.
I am running Windows 10, and I have been able to successfully load software to the remote in the past, it just takes more than 10 tries...
Does anyone have any info on how to resolve this? Thanks.
Lee
lee.jones is offline
Reply Remote Control Area
