Lets Talk MX-980 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #271 of 271 Old 04-17-2020, 03:45 PM
Wendell R. Breland's Avatar
Quoted: 609 Post(s)
Liked: 307
Thought I would post a link to my current MX-980 CCP file (a free site so a little patience). Click here to download. I have modified or created several button and background graphics.
For the Nvidia Shield Pro 2019: For direct IR control a Inteset IReTV USB IR Receiver is used, for several keys a FLIRC is used with codes from the URC database for a NEC CD player (remote codes 062). The numbers were from Pronto hex codes posted on the net.
For the Roku Ultra 2019: Most of the codes were from the URC database. For Netflix and Amazon apps, the cursor will move by 2 for each button press no matter if I told the MX-980 to send only one time (no repeats). For all other aspects the cursor works as expected. I procured a Inteset, Model INT-422-3 remote and it worked fine with the Roku so I learned the cursor into the MX-980. This works with Netflix and Amazon as expected except it will not repeat while holding down one of the cursor buttons even tho I have repeat set to on in the MX-980. So I use the database codes for the cursor pad and have 4 keys for cursor movement when using Netflix and Amazon.
mike1812 likes this.
Wendell R. Breland is offline
Reply Remote Control Area
Mx 890
