Sluggish controllers (multiple consoles) after bringing home new 4K TV - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By jeffbab
  • 1 Post By jeffbab
post #1 of 7 Old 09-04-2014, 02:44 PM - Thread Starter
Liked: 1
Greetings!
Long time lurker at this site, great knowledge and info to be had here. So I brought home a new LG 4K 240hz 3D LED TV this past weekend. I hooked it up, and attempted to play Mario Kart 8 on the Wii U. The controls were very sluggish though, rendering the game unplayable. I figured it was an issue with sensor so I recalibrate all of the controllers but the issue persisted. I then attempted to play a couple of games on the Playstation 3 and had the same issue. Is there something that could be causing interference that is weakening the signal from the controllers? I'm stumped thanks in advance for your help!
marszilla is offline
post #2 of 7 Old 09-05-2014, 12:57 PM - Thread Starter
Liked: 1
Even my DirecTV remote is acting a bit funny now, not reacting to commands and such. Anyone else seen this before? It happened only after the new TV was setup
post #3 of 7 Old 09-09-2014, 06:19 AM
DaverJ's Avatar
Quoted: 1780 Post(s)
Liked: 4046
You are experiencing display lag. Sorry to be the barer of bad news, but many 4K TVs have a lot of processing, which causes this input lag.
You might be able to make it playable by dialing in settings that turn off as much processing as possible, but the other solution would be to either get used to the lag, or get an additional low-lag non-4K TV for gaming only.
DaverJ is offline
post #4 of 7 Old 09-16-2014, 12:02 PM
jeffbab's Avatar
I recently discovered this as well, although this is only a 1080p set. I already had turned off all extra processing modes, but I still had the TV in theater mode. Switching it to game mode seems to have cured it (mostly).
DaverJ likes this.
jeffbab is offline
post #5 of 7 Old 09-18-2014, 05:24 AM
ES_Revenge's Avatar
Quoted: 463 Post(s)
Liked: 158
Most if not all TVs have some kind of "Game Mode" as described above (the noise that guy makes at the start of the video is retarded btw lol). This usually brings the input lag down to something much more tolerable for gaming. Some sets may still not be optimal but unless you're doing some hardcore/serious gaming you probably won't notice or won't care.
Only thing that might cause some issues for you is that with a 4k set, it's always going to be upscaling (well unless you're gaming with an R9 295X2 in 4K or something, lol) so that will likely introduce some unavoidable lag there especially with these earlier gen 4K sets. Anyway try finding the game mode in your manual and see if that makes it work satisfactorily.
ES_Revenge is offline
post #6 of 7 Old 09-18-2014, 08:31 AM
jeffbab's Avatar
Originally Posted by ES_Revenge View Post
(the noise that guy makes at the start of the video is retarded btw lol)..
You are clearly not a Canadian. To disrespect Bob and Doug is an offense punishable by revoking all maple syrup and back bacon privileges.
lol
DaverJ likes this.
jeffbab is offline
post #7 of 7 Old 09-19-2014, 09:09 AM
ES_Revenge's Avatar
Quoted: 463 Post(s)
Liked: 158
Lulz funny enough I am Canadian. I had totally forgotten that's where that came from--haven't seen those skits in a long time. Also the guy in the video above is much more annoying and I guess it caught me by surprise 'cause it just blasts you when you press play!
Back on topic though, it's odd he has so much lag on that W840 (in the video)... The W850, W800, W950 have tested with extremely good (low) lag scores. I'm assuming in Game Mode of course, but when in Game Mode they're in the 20-25ms range:
http://www.rtings.com/info/input-lag-tvs
Reply Home Theater Gaming
