75" TV at 6-7 feet too big? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-16-2018, 05:54 PM - Thread Starter
sgupta's Avatar
Quoted: 247 Post(s)
Liked: 161
Hey all,
So I'm considering a TV upgrade in the not-too-distant future. I've been using a 65" and I'm pretty happy with the size, though it would be possible for me to go up to 75".
My viewing distance for TV and movies is typically 8-9 feet, which I think 75" would be fine for. However, when I game (casual...mostly single player titles), I have a gaming chair I use, and it's placed 6-7 feet from the TV instead. I'm a bit concerned as far as seeing everything on-screen, etc. when sitting that close for gaming.
In your opinion, is 75" going to be too big for that distance?
Thanks for any advice!
sgupta is offline
post #2 of 8 Old 09-25-2018, 06:43 PM
Liked: 0
While the THX standard says you're too close, I personally game on a 65" TV from 7ft away, its perfectly comfortable for me, but there are times I catch myself leaning forward a bit. So I could get even closer if I wanted.
broken harbour is offline
post #3 of 8 Old 10-24-2018, 06:41 AM
mbyrnes's Avatar
Quoted: 138 Post(s)
Liked: 249
Originally Posted by sgupta View Post
Hey all,
I sit just under 7' from a 75" and if I could, I'd go bigger. Xbox One X looks amazing. PS4 Pro does as well. You adjust to the size. I used to game on a 120" projector from 10.5'. that was intense!
Xbox Live: TheRealMaxPower --- PSN: BeyondMaxPower---- Vizio P75-C1    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S, PS4 Pro, Astro Mixamp 2013, Soundblaster X7 (Sparkos Op Amps), Schiit Modi Multibit/Magni, LTA MicroZOTL2 headphone amp, Hifiman HE-X V2, AKG K702 65th Anniversary, Fostex TH-X00 Ebony, Monoprice Monolith M1060 (Vegan pads), DT990 Pro 250 ohm, Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #4 of 8 Old 10-24-2018, 08:13 PM
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 516
Not at all too close!
jedi1982 is offline
post #5 of 8 Old 10-25-2018, 12:23 AM - Thread Starter
sgupta's Avatar
Quoted: 247 Post(s)
Liked: 161
Awesome - thanks all. I've decided I'll likely go for it in the near future. =)
sgupta is offline
post #6 of 8 Old 02-10-2019, 06:00 PM
Liked: 0
Id go for it.
makarimi is offline
post #7 of 8 Old 02-11-2019, 06:52 AM
rr6966's Avatar
Quoted: 48 Post(s)
Liked: 79
You are good to go!
rr6966 is offline
post #8 of 8 Old 03-12-2019, 11:27 AM
Quoted: 16 Post(s)
Liked: 0
Definitely not too close. Particularly if you end up playing anything with text you'll appreciate it being relatively large. It's a pain when you have to strain to read the UI.
lessthanjoey2 is offline
Reply Home Theater Gaming
