Is Xbox One X really worth it for 4K? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By camcamaro1991
  • 1 Post By newfmp3
post #1 of 15 Old 11-24-2018, 07:35 AM - Thread Starter
thekage's Avatar
Quoted: 26 Post(s)
The same game side by side, one in regular 1080 and the other 4k, is the 4k version really that much better? Is it truly 4k? Thank you.
thekage is offline
post #2 of 15 Old 11-25-2018, 04:29 PM
camcamaro1991's Avatar
Quoted: 74 Post(s)
Liked: 52
X1X, is true 4K if the game is 4K. There is a list available... https://www.xbox.com/en-us/games/xbo...-enhanced-list
Resolution isn't the only thing you gain, HDR typically comes with 4k so its 2 for 1. Yes 4K is worth it alone, with 4K HDR you gain more pixels images are sharper, cleaner. HDR offers wider color gamut, with brighter bright & darker darks. I honestly think its more of the TV you have, cheap TV's = cheap results, premium TV's deliver the full experience. The X1X can also down sample meaning take a 4K assets and blend them with 1080p, making native 1080p look fuzzy in comparison. I have Titan fall 2 with 4k, The Division (HUGE improvement over the standard non 4k assets) Halo, Gears of war, all the staple X games. There are so many approved 4k HDR games on X1X, with the ability to down-sample them is crazy good for any 1080p players, with the option of 120hz is just nuts. Pony's get slapped on their fake 4k console.
With that said I also have a Oppo-203 player, which kills the X1X 4k player, Oppo allows much greater depth in the same image, including Dolby Vision via disc, currently the X1X can only stream DV via apps, which for 90% of most folks is less than ideal given the internet band width required to watch true 4K HDR DV.
Kev Greenhalgh likes this.
Sony Tri-75" Z9D's / 75" 850C / Apple 4KTV / OPPO UDP-203 / twin X1X Scorpio's
camcamaro1991 is offline
post #3 of 15 Old 11-29-2018, 03:17 AM
highd3f's Avatar
Quoted: 135 Post(s)
Liked: 79
Xbox One X is the only gaming console currently available on the market that can output true 4K resolution. On top of that, as @cmcamaro1991 said, you get HDR which improves colors. That coupled with extreme sharpness and smooth gameplay, not to mention safe gaming community with no fear of your credit card info going into the wrong hands, and you'll be one happy gamer. PS4 Pro peasants are holding onto their exclusives, but see them dropping them dollars and saying how you can have both just so they can justify the purchase of their inferior device. What about PC Master Race you say? Well, if you want to learn how to use cheat codes before you ever learn how to play a game, sure go ahead.
Xbox One X is the only wise choice right now and has literally no competition for the features you get and the price you pay. I'm sure you want to spend your holidays having fun, not crying in bed regretting your purchase.
highd3f is offline
post #4 of 15 Old 12-02-2018, 01:35 PM
Quoted: 59 Post(s)
Liked: 44
On it's face, yes, if you have a TV set of the quality of a Vizio PQ, the Xbox One X is worth it, especially if you don't also own a 4K blue ray player. However, X Box 2 Scarlette is likely going to be shown at E3 2019 and out by early/mid 2020. The question is would you have buyer's regret when the next device is giving true 60 FPS in 4K at 120Hz on the newest TVs. At this point in time, we are about a year from the next major XboX release and then PS5 is a year later in 2021. I'd go ahead and buy now if you have the moey and a good TV set as life is too short to wait for everything or you could wait forever.
Grimbor is offline
post #5 of 15 Old 01-06-2019, 06:26 PM
RobZL1's Avatar
Quoted: 37 Post(s)
If you have a good 4k TV then go for it. You'll be pleased. However, if you run surround sound you'll also need a.4k capable AVR. And don't forget 4k HDMI cables (the XBX comes with one... they're not expensive, but they are different).
Regarding the future and buyers remorse... I see it the opposite way. I'd regret owning a 4k tv and NOT playing 4k games.
Also consider when the next gen comes, if it is 120 hZ refresh rate, THAT will also require a AVR upgrade for most users. Suddenly, the console itself seems like the least expensive part of the equation....
AVR: Denon X4400H 7.1.4; 80% gaming, 20% movies, <1% music
Speakers: Klipsch RP-450C; L/R Klipsch RP-250F; Side & Rear: Klipsch R-51M; Height: JBL 2.5" satellites; SVS PC-4000;
Platform: Xbox One X on LG E8 55" OLED
Room from hell: 16x16x18' open loft, thin walls, hard surfaces, lots of street noise
RobZL1 is offline
post #6 of 15 Old 01-07-2019, 05:10 PM
rhed's Avatar
Quoted: 696 Post(s)
Liked: 590
Yes and yes. And if you have a display that supports Dolby Vision, even better. Cause X1X is the only gaming console to support DV. Lots of movies encoded with DV. And a handful of games is starting to come out with DV. https://www.dolby.com/us/en/categories/games.html
rhed is offline
post #7 of 15 Old 01-08-2019, 01:05 PM
david8613's Avatar
Quoted: 319 Post(s)
Liked: 67
I say yes, I went from a 70" 1080p sharp television playing my games with a ps4 pro, to a Samsung 82" Samsung nu8000 running an xbox one x. I can see a big difference, not just colors, resolution and overall picture quality but also in how the games run. the xbox one x and Samsung nu8000 combo is excellent, the Samsung has a lot of gamer specific features and the games play so smooth, like silk. When I run my xbox one x on my sony 45es projector which is an excellent projector, I can see the difference between 4k to 1080p easily, sharper, more detailed, more colorful...
david8613 is offline
post #8 of 15 Old 01-27-2019, 11:20 AM
Liked: 1
Yes its worth it every penny. You can see more details and overall experience is really good
Outer404 is offline
post #9 of 15 Old 01-28-2019, 09:30 AM
Liked: 1
I wondered a similar thing too, but the one thing that let me know I made the right decision by going 4k was I used the Xbox to record something. I then went back to look at the recording, which is not done at 4k, and it was night and day in the picture quality difference from the game I was just playing. I could flash back and forth between the two and I was happy to have made the change.
DillonSUG is offline
post #10 of 15 Old 01-29-2019, 04:34 AM
david8613's Avatar
Quoted: 319 Post(s)
Liked: 67
yes definitely!
post #11 of 15 Old 01-29-2019, 07:37 PM
Quoted: 31 Post(s)
It's been well worth it for me, highly recommend it!
rinse82 is offline
post #12 of 15 Old 02-09-2019, 12:49 PM
BL4DE's Avatar
I think the next gen comes out 2020 so might be worth waiting for. Or just sell the X when it comes out which is what I'm doing
JVC RS 540
7.1.4, Hsu Research HB-1 MK2 surrounds, HC-1 MK2 center, VTF-3 MK5 sub, Klipsch RP-280FA fronts, and RP-140SA rear heights
Denon X6400H
Xbox One X, HTPC
BL4DE is offline
post #13 of 15 Old 02-10-2019, 05:55 PM
Liked: 0
yes
makarimi is offline
post #14 of 15 Old 03-08-2019, 03:40 PM
Quoted: 21 Post(s)
Liked: 4
I'd recommend waiting until E3 in three months to see if Microsoft announces the next generation console. The One X is a nice upgrade but it might only be 2 years until the next console comes out and I don't think it would be worth the upgrade at this time.
Havfan is offline
post #15 of 15 Old 03-11-2019, 10:49 AM
newfmp3's Avatar
Quoted: 420 Post(s)
Liked: 348
2years? No way I'd wait 2 years. If you already got a 4k tv, what's another few hundred to enjoy 4k and hdr as it's meant to be enjoyed. In two years we could be using even better TV's. You only live once, if you can afford it, get it now, it's well worth it over a xbox one s.
newfmp3 is offline
Reply Home Theater Gaming
