Any data on lowest bass frequencies used in games? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-06-2019, 06:38 PM - Thread Starter
RobZL1's Avatar
Quoted: 37 Post(s)
Are designers using low bass frequencies in games? 20hz? 16hz? Is there any data out there on the topic? I'm wondering what the ideal subwoofer is for home theater gaming. My SVS PC2000 can hit 16hz.... But do I need more!?!
AVR: Denon X4400H 7.1.4; 80% gaming, 20% movies, <1% music
Speakers: Klipsch RP-450C; L/R Klipsch RP-250F; Side & Rear: Klipsch R-51M; Height: JBL 2.5" satellites; SVS PC-4000;
Platform: Xbox One X on LG E8 55" OLED
Room from hell: 16x16x18' open loft, thin walls, hard surfaces, lots of street noise
RobZL1 is offline
post #2 of 2 Old 02-09-2019, 12:51 PM
BL4DE's Avatar
I don't know the actual frequency, but the LFE from the opening Xbox 360 logo when starting the console sounds awesome if you have the volume cranked and at least one port open
JVC RS 540
7.1.4, Hsu Research HB-1 MK2 surrounds, HC-1 MK2 center, VTF-3 MK5 sub, Klipsch RP-280FA fronts, and RP-140SA rear heights
Denon X6400H
Xbox One X, HTPC
BL4DE is offline
Reply Home Theater Gaming
