How can I get losseless and 4k gaming from new pc? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-05-2019, 06:29 PM - Thread Starter
chris6878's Avatar
Quoted: 35 Post(s)
So I upgraded my PC and TV. I used to run my old pc hdmi through my receiver into tv. But now with 4k I see my pio doesnt pass through. I plugged the pc hdmi into the tv and its 4k hdr all the way, but I cant get lossless sound, only crappy optical. Any suggestions. My set up:
LG C8
oppo udp 205
Pio VSX-92 TXh
nintendo switch
Brand new PC with all the fixins for 4k hdr, dolby vision.....and what ever else ready. Mostly want to game.
Is it time to upgrade my PIO or can I do some tricks with the oppo?
chris6878 is offline
post #2 of 9 Old 05-05-2019, 07:04 PM
Liked: 1
LG C8
oppo udp 205
Pio VSX-92 TXh
nintendo switch
Oppo in is native 4k. Maybe try PC-->Oppo-->Pio/TV. 205 has 2 HDMI out and 1 in. Use the Vid out for tv, audio out to go to Pio
Sam F is offline
post #3 of 9 Old 05-06-2019, 05:30 AM - Thread Starter
chris6878's Avatar
Quoted: 35 Post(s)
OK ill give that a shot.
post #4 of 9 Old 05-06-2019, 02:00 PM
Quoted: 343 Post(s)
Liked: 200
LG C8
oppo udp 205
Pio VSX-92 TXh
nintendo switch
If your motherboard has it's own audio you can split audio and video. PC GPU to tv via hdmi/ motherboard audio(hdmi) to avr. You will have to go into sound settings to configure your setup(5.1,etc.). I would suggest this over the oppo because of possible lag.
Friendlys is offline
post #5 of 9 Old 05-06-2019, 02:18 PM - Thread Starter
chris6878's Avatar
Quoted: 35 Post(s)
OK, I had tried that yesterday but couldnt figure out how to get the mobo to output sound
post #6 of 9 Old 05-06-2019, 02:22 PM
holl_ands's Avatar
Quoted: 956 Post(s)
Liked: 523
HDMI can only support ONE Format at a time. UDTV will ALWAYS request STEREO Audio, cuz it only has 2 Internal Speakers....so most HDMI Splitters will only give you STEREO on the Secondary Port. [Or SURROUND on BOTH ports if connect Primary to AVR???]
Most BD/UD-Players solve this problem by providing TWO Independently controlled HDMI Output Ports: Primary goes to UDTV (with STEREO) and Secondary goes to AVR (for Surround, incl. Loss-Less).
You should investigate what is needed software-wise to support TWO Independently Controlled HDMI Output Ports in your PC....
Alternatively, you might want to investigate various HDMI MATRIX SELECTORS to see if you can Input SURROUND (incl. Loss-Less) and pass-thru that format to the AVR and let it automatically "DOWNMIX" to STEREO on the Port connected to UDTV.
holl_ands is offline
post #7 of 9 Old 05-06-2019, 03:10 PM - Thread Starter
chris6878's Avatar
Quoted: 35 Post(s)
well I hooked it up via the oppo. Played ok at first, then I started getting lag. Also tried to play a game and the game wopuldnt even output video correctly. So thats out. Im gonna do some research on how to output sound from the mobo.....but now its starting to look like I need a new avr.
post #8 of 9 Old 05-06-2019, 08:31 PM
Quoted: 343 Post(s)
Liked: 200
Your motherboard will have specific sound drivers online for your mobo. You need to enable sound via your bios first. Then download drivers... next go to sound properties and enable the correct set up. It will either have the name of your avr or intel. Right click to test and configure.
Yes, I had used this method for years until I purchased a 4k avr to pass through my 4k tv. Whomever says there is an issue between to hdmi outputs not working is incorrect. You can Google this online for a step by step explanation.
post #9 of 9 Old 05-07-2019, 08:10 AM - Thread Starter
chris6878's Avatar
Quoted: 35 Post(s)
Which do you like better and more convenient? im gonna try the mobo sound tonight, before I thibk about a new avr....even tho the Anthem MRX 720 has caught my eye.
Reply Home Theater Gaming
