BenQ EL2870U 28 inch 4K/HDR 1ms GtG Gaming Monitor Review - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By sage11x
post #1 of 1 Old 12-30-2019, 01:20 PM - Thread Starter
sage11x's Avatar
Quoted: 2964 Post(s)
Liked: 3055
Hey I wasn't sure where to put this but decided it probably needed to go to the display thread. But since this is definitely a gaming focused topic I figured I'd link to my review here.
https://www.avsforum.com/forum/166-l...l#post59023272
maglo125 likes this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
Reply Home Theater Gaming
