No Atmos under Windows 10 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-12-2020, 02:46 AM - Thread Starter
Michael2907's Avatar
Quoted: 39 Post(s)
Liked: 0
Hello, I also have problems with Dolby Atmos under Windows 10.
My setup is gtx1080ti to Yamaha rxa3080 AVR and then to a jvc beamer.
The surround sound is always greyed out.
I have a 7.1.4 setup and movies with VLC or mpc-be run fine.
In the Dolby Access App the movies also send Atmos to the AVR, but a message appears that Atmos is not activated.
I have tried many drivers, installed and uninstalled Dolby Access App several times.
I don't know any more
I forgot to mention that I only have this problem with games, respectively the apps I downloaded from the Microsoft Store...
Netflix, Forza Horizon 3 and 4
Translated with www.DeepL.com/Translator (free version)
Gesendet von meinem SM-N960F mit Tapatalk
Michael2907 is offline
post #2 of 4 Old 06-12-2020, 03:38 AM
markmon1's Avatar
Quoted: 6820 Post(s)
Liked: 4943
The first thing you need to do is get rid of the dolby atmos app. You should have your audio player *bitstream* the audio to your receiver. You do not want to have your player decode the audio on the pc side. VLC may not be able to do this. But MPC can using LAV filters. Make sure you configure the LAV filter audio output by telling it all your codecs are playable by your receiver.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is online now
post #3 of 4 Old 06-12-2020, 03:57 AM - Thread Starter
Quoted: 39 Post(s)
Liked: 0
post #4 of 4 Old 06-16-2020, 05:37 AM
Quoted: 26 Post(s)
Liked: 9
I'm having a problem following you, so you do have this issue with netflix?
beyondm3 is offline
Reply Home Theater Gaming
